Leading Edge extensions
1 post in this topic
Didn't want this buried below what was already written.
Any engineering and lift-conscious, CG calculating minds out there?
I see a problem with the tips of the wings being too wide when folded with the 3 inch extended LE, because of the width of the Vertical Stabilizer.
Question: What effect would there possibly be on the CG if the ROOT was extended 3 inches, and a constant taper on the LE to the tip, or at least back to the VS when folded?
Would this be the same as estending the whole LE One and one-half inches, or would it be greater than that, since the main lift is near the root?
All comments welcome - Hope someone has some calculations.
ED in MO
