Avid Flight Manuals
12 posts in this topic
Use these at your own risks! They are for general information only.
Model C POH.pdf
Some had some time on their hands to make up that POH.  One question.. Typo or would there be a reason that he listed best glide as 55 yet in the emergency procedures he says glide at 50.  I dont know about you, but if I want my plane on the ground RIGHT NOW, I just pull the nose up and slow it down.  In mine at 50 I am dropping at about 1200 FPM, 65 gives me around 750 FPM.  Not too bad for being on floats, but not too good either :lol:
I was taught to point the nose DOWN... ;)
If you want to loose altitude in these quickly, just pull the nose up and slow them down.  I can loose altitude quicker at 42 MPH than I can redlined.  I did a stall series last time home on floats.  45 MPH power off had me dropping at 1700+ FPM, 65MPH had me dropping at 650-700 FPM.  At any rate, you dont want to loose an engine when on floats, it glides like a greased anvil :lmao:
What is an AEROBAT? Is this a short-wing Avid stressed for aerobatics?
I am sending the flight maneuver manual to Trackwelder to post.
The aerobat is the speed wing that I think was built to the HH specs (spars and rib spacing).  There is a video of the MK IV on the net where the guy is flying inverted, 4 point rolls etc.
Good job on the manual!  Do you know of one for the Rotax 582???
I am not an Avid owner, but Kitfox had same engines - The 582 is basically an improved 532:  It is same 65 hp, but a later version with gray head, and still later, a blue head.
The POH above is for the C model.  Different models will have different weights which will affect airspeeds somewhat - I think the model IV is heavier MTOW, than the C model.   Some Avid owner should know about the serial number range for the model IV.
Model C POH.pdf
Joey, The one error that I see in the manual is on the first page:  Weights:  580 solo, 850 dual.  Does this mean the Co-Pilot weighs 270 lbs? ???  Would that be the weight of one of the AFF members?
I would think that 580 would maybe be Empty Weight?  Still don't Compute!   I think the GW is 911 on page 2.    EDMO
Ed the early Avids weighed in at barely 400lbs. They gained a lot of weight really fast when the market demanded all the goodies. Factory numbers were all for advertising in the early days and didn't hold much merit.
Yes Joey - I really wanted to be careful about that 270 lb Co-pilot on the chart (might be somebody's spouse - Or my Ex!)   EDMO
Thanks guys.  I was able to find both the OH and MM for the Rotax 582 online.  Thx again
