Avid Builders Manual and AD's
11 posts in this topic
Builders Manual broken up into several files to keep the size reasonable. Also the AD's that were available at the time I posted this are here. If you have any that are not posted here please scan them and add to the list!!
Builders Manual part 1.pdf
Builders Manual part 2.pdf
Builders Manual part 3.pdf
Builders Manual part 4.pdf
Builders Manual Part 5.pdf
Avid Airworthniness Directives.pdf
Joey, do you know if this manual was tailored to a particular avid model?
It was the b or c model.. I have the additional pages for the mk iv too that shows the upgraded cooling etc. I used this manual for my c model rebuild.
Question on the manuals, I know you said they are taylored to the b and c models. Will they work for the A model and if not is there manual out there for the A model?
The A model manual is not very complete, half as thick as later ones.   Most everything in the later manual should be applicable to the A model.  Rigging flaperons and such should all be the same as they use the same linkage.  The A model came with a Cuyuna engine, so you probably aren't using that anyway.  Early brakes were cable operated, later of course went to hydrolic ones.  Jim Chuk
Thanks Jim.
Akflyer,
i just got a mark iv but no manuals. Do you still have the manuals for it?
I can open the files above which contain the entire manual. Is no one else able to open them?
I can't on my 7 year old PC but they work fine on My wife's Mac.
TJay, try opening the files I just posted in the original thread.  They should now open up and they have the MK IV additions as well... at least in as much as I had in the manual I had with my plane.
Well holy Hell they work, There you have it, an antique computer can now open the books, Nicely done,
