California Power Systems 2-Stroke Tech Articles all in one place
38 posts in this topic
Rotax 2-Stroke Disassembly
Good technical information a teardown. Includes how to measure cylinder and piston clearances. Includes several pictures of failed pistons and the cause of the failure.
Rotax 2-Stroke disassembly.pdf
Stealth Rotax intake silencer info
Operators in Europe face strict noise requirements. This article discusses the intake silencer and secondary muffler. General consensus is all they do is reduce performance and do very little for noise reduction.
Stealth Rotax Intake silencer info.pdf
Taking control of what your engine burns
A good discussion on various additives that might wind up in your fuel including the ever popular ethanol discussion.
Taking control of what your engine burns.pdf
The new 582
This is an article that highlights the changes that made the 582 with true dual ignition superior to the single points ignition 532.
The new Rotax 582.pdf
The Rotax Decision: A side by side comparison
An excellent article showing long term operating costs between all the Rotax engines. Also a good side by side performance comparison. This article is an excellent choice when trying to decide between a 582 and a 912.
The Rotax Decision-Side by side engine comparisons.pdf
The Ducati Ignition: Timing-Troubleshooting-Utilizing it's ouput and understanding your electrical system
Timing and Troubleshooting information on the Ducati Ignition. Great information on how the digital ignition system works. The other attached article shows diagrams on how the lighting coil interacts with your voltage regulator. Good wiring schematics and information to help you troubleshoot if you find yourself with no power output or spark.
Timing the Ducati ignition.pdf
Troubleshooting the Ducati ignition.pdf
Understanding the Electrical System.pdf
Utilizing your Ducati Generator output.pdf
Tuning the Bing 54
Excellent article on the art of 2-Stroke Tuning
Tuning the Bing.pdf
Understanding 2-Cycle lubricants
People will debate for hours on what oil to use and at what ratio. This article will help you sound educated when engaged in one of those arguments.
Understanding 2-Cycle lubricants.pdf
Understanding the Choke circuit (Enrichener)
Primer or Choke? Good discussion on how the Enrichener circuit in a Bing works.
Understanding the Choke.pdf
Understanding the Mid-Range circuit VERY IMPORTANT ARTICLE!
One of the easiest way to burn up a piston is by not understanding how the Mid-Range circuit of a two-stroke works. Please take the time to read this article and understand what it is saying and how to apply it the operation of your engine. In a nutshell: Don't pull the power back to 4000-5000 rpm and unload the engine by starting a slow descent like you would with a traditional engine. Your EGT's will quickly exceed the redline of 1200 degrees.
Understanding the Mid Range circuit.pdf
Using the right Rotax tools
Information on the Rotax specialty tools available and what they are used for.
Using the right Rotax tools.pdf
What to do when it quits
There are two mistakes a pilot often makes after an  engine quits. First it quit for a good reason. Don't try and restart it. You'll likely destroy the evidence that made it quit. Second don't automatically blame the engine for your troubles. The majority of Rotax engine stoppages are due to a fuel starvation issue.
This article is another great troubleshooting source.
What to do when it quits.pdf
What to know after a propstrike
Evaluating the integrity of your engine after experiencing a prop strike.
What to know after a prop strike.pdf
