LIFT STRUT TEST
7 posts in this topic
Attached is copy of Kitfox lift strut test.  Note that the Kitfox 2 used 7/8" diameter struts.
The thumbnail is large, and when you click it gets larger - someone can resize it if need be - I donno how!
Also NOTE:  I don't think there was any wood on the struts for this test!   But, this was a test in tension, and not in compression.
Thanks for putting this up Ed, I've been thinking about my lift struts lately as I have the original 3/4" struts and am looking for the best way to go. Been thinking about just cutting the tubes about 6-8" from the ends and sliding 7/8" - 1" tubing over the stubs and welding it all back in place. seems to be the easiest way to strengthen them. I think the ends are supposed to be strong enough. what are you guys' thoughts? If I have to build them both from scratch I'm thinking it might be good to add a rod end to both sides... ???
I think you should be just fine by splicing the larger tubing over the stubs - you should fishtail and rosette weld, as per AC43-13.
- I had to make new struts and didn't want to cut up the old 7/8 pair because they were good.   My new ones are longer and the fuselage attach fitting has to be at a different angle.
I happened to find some nos aircraft rod ends at a cheap price - and they are 7/16 thread and 5/16 bolt - didn't think I needed the bigger ones, but it wont hurt either, so going to put them on all 4 struts.  Using 1" x .049 wall tubes.
So do you still have the old 7/8 inch pair? forsale.
TJay,
     I have them, but since the strut fittings on the spars were located by the builder, there is a very slim chance that the struts would be correct for your plane if your fittings are attached.   Better and cheaper, I think, to cut ends off yours and put heavier tubes on them, making them the exact same length and width.  I don't know if anything about them changed between the KF1 and the KF2 models, or just diameter.  I think that the incidence was changed, so maybe struts changed too.  Mine would be good for someone who did not have their wing fittings installed.
yeah I should just make new stronger ones, I wonder how much the stock 3/4 inch ones will really take. Never heard of one failing so maybe building stronger ones is just adding weight again?
TJay,
    go back and read the strut test again - probably someone with engineering figures like Luke could figure it out, but if a 7/8 held for 15 Gs, (and only quit because a rod-end failed), your struts should exceed your GW by a LOT, IMO, probably more than your spars.
     I never have heard of a strut failure for any of the Foxy Avids....I had to make new ones because mine have to be longer, and a different angle because I raised my roof and wings.
