F/S: Elevator push/pull control tube with heim ends
1 post in this topic
....SOLD....SOLD....SOLD....SOLD....SOLD....
This was buried in one of my earlier ads...
I have available (1) complete oem Kitfox elevator push/pull control tube. Removed from a model 3 in good working condition. This includes the following part numbers:
(1) FCT-69 [Elevator Control Tube 1" o.d. x .035" wall x 112-1/2" length aluminum]
(2) FAB-13 [Adapter Bushings]
(2) AN490HT8P [Threaded Rod Ends]
(2) AN316-4 [Threaded Rod End Lock Nuts]
(2) FRE-50 [Rod End Heim Bearings]
Note: in addition to KF3, this may be a direct fit for KF1-2 models (see pics for measures) or very easy to trim to length. Possible replacement for Avid Flyer and other similar elevator control systems.
Offers accepted for pick up at D38, must make your own shipping arrangements. Due to length, it might be cheaper to cut the ends off for reuse with your own locally sourced aluminum tubing. All I know is I don't need it, maybe you do?
Thnx
Edited by dholly
