IVO Magnum Right Turning 68" Prop.
2 posts in this topic
Hi,
If you have a right turning ivo magnum 68" prop I would be interested in purchasing.
You probably need an SAE-1 Hub for the Continental engine, and most available on here are Rotax. Unless it has a Rotax adapter on the crank. Try Barnstormers.
I need an SAE-2 hub, which is same as Lycosaurus.
