LED landing lights
31 posts in this topic
I see only one controller listed separately. It is specifies 5 amp capacity in each channel, left and right. For most LEDs that seems pretty hefty, IMO. I would think there are other suppliers with differing amperage ratings.
Edited by KFfan
afterthought
Larry,
      I am uncertain if you want the controller for the Crazed Pilot LED lights, or for the Vision X lights - I believe Leni tried to use the controller for Vision X or some other lights and it would not work with them.  I don't know if there are two different controllers for CP lights.  I have had these for about 2 or 3 years.
Id like to use the crazed pilot controller for my installed lights.  Per the specs given, this should work. But I know Leni had trouble. I was hoping that the controller was updated to truely allow the spec that they advertise.
I've got one of the flasher controllers made here in Missouri - Don't have a clue if it will work with just two LED lights, but I also have two 100 watt halogen landing lights that I could add to the LED circuit if I have to.
How old is the crazed pilot set you want to sell, Ed?
From the papers in the box, I am guessing about the first of 2012.  No model number found.
Would you be better off to talk to Crazed Pilot and maybe buy the controller without the lights?
