Corroded Lift Struts
5 posts in this topic
Here are some pics of the lift struts I replaced on my "C" HH. The covering was in good shape, but I could see some rust beginning to show under the paint right above the lower strut attach. I pulled the covering off and the wood fell off in most places. There were a few areas that the epoxy had actually held on and those areas were OK, but all the areas the epoxy had not adhered real well, it looked like crap and was all rusty. I started to sand blast and was just going to recoat and put them back on, but after looking them over I said BS on that noise and made new lift struts.
1047_7d75fb5ada8c96cb899bc5867169d2514ac
1049_74d5b9395355dc242b744156fe513be967d
1051_7c910965eddbf7a0312f377ccc495ee64ee
1053_d026653bebd1fe6bd971e8bb56d731b9436
1055_d70674caf724fb66e8ad28b1abc5c06194a
1057_a37a46c999ce3f8dc8baaf95831ef4809b3
1059_53e6da3d3fc93abf9a4c942ff6809b385bc
1061_125434ae8e14b55045c2e9e310927f36cb2
1063_4c58709c3b53e8eaedcf3d88f4b1fd4132e
1065_fabf6f5b9d8066ec4e6435f75c4843af69c
Yikes that's kind of scary. Mine appeared to be awesome shape during my rebuild. Maybe I should cut into them and make sure.
Would not hurt to have them Xrayed just like you would a piper strut.  Spend 2-300 hundered bucks on the Xray and you would have to wonder anymore..
AK FLYER I know when yu built your new lift struts you went with a larger diameter and ticker tubing, fr your adjustable ed did you have it custom machined or were youu able to find an off-the-shelf part. I amlooking atdoing the same thing but I want to make sure I am doing it safely, I mde new spar carry throughs out of 1 and 1/4 inch tubing and amlooking atwhatI will need to do to strengthen the seat truss for larger landing gear but wthot access to a lathe the adjustable threaded joint looks to be a hod up, any ideas. I am trying to build this to haveabout a 600lb load limit.
I cut the ends off my existing struts and slid them into the new 1"X.058" tubing. I made a good wide fish mouth on the tubing and welded them on. I also bought a new threaded rod end from AVID and welded that in because mine had been bent in the wreck.
