Wanted, Rotax A or B gearbox
3 posts in this topic
Hi all,  I'm also in the market for an A or B gearbox, 2.58-1 if possible.  That Kitfox I just picked up had a prop strike, and the prop shaft got bent.  The early A gearbox has a bolt on the end of the prop shaft holding on an aluminum hub, and I was told to stay away from that, otherwise, what have you got?  Thanks Jim Chuk    email   avidflyer6014   at  gmail  dot   com  or phone  218-254-2404
Did you get a gear box if not I have several A models all are 2.58 and have steel prop flange with ring around flange to indicate 12 thrust washers $250.00 and shipping
I did end up getting a B box.  Almost tempted anyway to use as a spare.  I actually have a B box with a bent prop shaft.   Think the later A and B boxes use the same part.  Thanks,  Jim Chuk
