Yamaha RX1 Engines
562 posts in this topic
Any of the digital tachometers that I have looked at only go to 9999 rpm and it would be nice to have a steam styled gauge to match the rest. I am told that I need one to count 6 pulses pre revolution. Any suggestions where I might find such an animal in a 2 inch?
I don't know why you would need 6 pulses/rev. on a 4cyl/4stroke engine.  My tach has a switch on the back to set it for 4,6,8 cylinder engines.  ???  My tach probably only goes to 10K - I never cared what it went to because I only turn about 5K max.  I also bought a Tiny Tach knockoff.  You might find a SnoGo or Racing Car tach that goes to 12K, but guess most are digital now?   What does Yamaha use?  EDMO
The pulses per rev
 Has nothing to do with the number of cyl. Or number of cycles it fires at. It is only the number of electric pulses the ignition or lighting coil puts out per rotation. I believe this engine uses the lighting coils pulses which is probably 6 lighting coils.
The pulses per rev
I didn't know any tachs worked off of lighting coils, but there is a lot about SnoGos I don't know.  All the tachs I know about just take a signal from one plug wire.   EDMO
A new nose is shaping up.  A little fairing compound and it'll look pretty decent
Is that a hidden piano hinge wire I see sticking out in front?  Nice job.  EDMO
Yep
Yeah man!
Hope mine turns out half as nice as that!
Cowl getting a fat lip for the new radiator....
The radiator and female side of mold.
Very nice!
And thanks for the pics.  It'll help to give me some ideas on putting mine together!
Going with a Kool prop?
Edited by MN Kitfox 2
can you run a two blade prop with the RX-1. is it possible to save weight that way?
Steve henry has a couple hundred hours with a 2 blade prince with good results.  I like the idea of that to save MMOI more than straight weight.
Got the RX-1 fired up last night now I'm getting excited. Has anyone tapped into the oil pressure test port on the head and if so what oil pressure are you reading?
You really have an outstanding accomplishment.
You mentioned the oil test port.  A spring loaded check valve and auxiliary/prelube oil pump may be able to hook directly into the oil pressure test port.
Since the RX-1 is a pressurized oil system, I wonder if its TBO would benefit from a pre-lube pump and maybe even a pre-heater incorporated into the pre-lube system?   This could additionally provide a convenient means of having a light weight cabin heater system.
http://turbowerx.com/Scavenge_Pumps/Exa-Pump/Exa-Pump.html
Since the RX1 was made to be a vertical motorcycle engine, I would imagine the oil pickup would lose oil pickup supply during negative G's, climbing, slipping, and (if considered) inverted operations.
I would guess that Winter and daily starting, as well as starting after long times between starting, would benefit from pre-lube and pre-heat.
Edited by JimD
Not sure of the negative G's, but cold weather starts, I envision, should not be an issue, as these are sled engines.  I had one and it would fire up easily, even at -10F.  Quite incredible for a 4 stroke.
Edited by LSaupe
Here is a picture of the  engine mount glen (flyingwrench) makes and has for sale.
how can we get ahold of the flying wrench?
Glen David (AKA flying wrench)
(623) 256-4115
Was there any mention of what this motor mount costs?  JImChuk
I would agree that the pump is a nice little ad-on but would rather be able to monitor oil pressure. On a different subject what is everyone using for a tractor prop diameter and pitch?  I have limited ground clearance in my Zenair CH701
First start up.  It fired right up.... after I opened the fuel valve.
20170706_215731.mp4
Are you running a clutch on there?
Yes, rk 400
