Yamaha RX1 Engines
551 posts in this topic
Nice !!!! How is weight distribution? The angle is not so unusual, just wondering how balanced it turned out.
Got some more work to do before I break out the scales.
Here is a picture of the  engine mount glen (flyingwrench) makes and has for sale.
Since the RX1 is a 4 stroke, is it quiet in the cockpit? As compared to a 2 stroke.
Can you post a YouTube with your engine running?
Edited by JimD
The RX-1 turns upwards of 10,000 rpm on takeoff. Steve Henry had to do a lot of trial and error with exhaust systems. He said on his first version it was so loud that it was absolutely deafening in the cockpit.
Might be a good reason to start making the Swiss Mufflers?  EDMO
Anyone have a recommendation for a analog tachometer preferably a 2 inch version?
I got a 3" analog tack at O'Reilly Auto Parts - They may have a 2" version?  EDMO
Recommendation:  Don't buy one.
This forum is littered with stories of inaccurate and failed analog tachometers.  A digital tach  is far more accurate and reliable.
Any of the digital tachometers that I have looked at only go to 9999 rpm and it would be nice to have a steam styled gauge to match the rest. I am told that I need one to count 6 pulses pre revolution. Any suggestions where I might find such an animal in a 2 inch?
I don't know why you would need 6 pulses/rev. on a 4cyl/4stroke engine.  My tach has a switch on the back to set it for 4,6,8 cylinder engines.  ???  My tach probably only goes to 10K - I never cared what it went to because I only turn about 5K max.  I also bought a Tiny Tach knockoff.  You might find a SnoGo or Racing Car tach that goes to 12K, but guess most are digital now?   What does Yamaha use?  EDMO
The pulses per rev
 Has nothing to do with the number of cyl. Or number of cycles it fires at. It is only the number of electric pulses the ignition or lighting coil puts out per rotation. I believe this engine uses the lighting coils pulses which is probably 6 lighting coils.
The pulses per rev
I didn't know any tachs worked off of lighting coils, but there is a lot about SnoGos I don't know.  All the tachs I know about just take a signal from one plug wire.   EDMO
A new nose is shaping up.  A little fairing compound and it'll look pretty decent
Is that a hidden piano hinge wire I see sticking out in front?  Nice job.  EDMO
Yep
Yeah man!
Hope mine turns out half as nice as that!
Cowl getting a fat lip for the new radiator....
The radiator and female side of mold.
Very nice!
And thanks for the pics.  It'll help to give me some ideas on putting mine together!
Going with a Kool prop?
Edited by MN Kitfox 2
can you run a two blade prop with the RX-1. is it possible to save weight that way?
Steve henry has a couple hundred hours with a 2 blade prince with good results.  I like the idea of that to save MMOI more than straight weight.
