Rotax 912/914 Service Letter Dtd 30-DEC-2016
1 post in this topic
SL-912-016R1
SL-914-014R1
This SL revises SL-912-016/SL-914-014 initial issue dated 28 July 2009
Reason
Field experience has shown that additional information is necessary on the handling (Aircraft Operators) and the installation (Aircraft Manufacturer OEM’s) of ROTAX® aircraft engines type 912 and 914.
The areas of special importance are:
- Engine load (power setting) and its effect on the possibility of detonation and/or pre-ignition
- Idle speed setting
- Carburetor synchronization
- Using high fuel quality
- Balancing of the propeller
- Compliance with installation specification to the exhaust back pressure
- Compliance with the required airbox temperature
 SL-912-016 R1_SL-914-014 R1_Essential information regarding engine behavior, performance and manifold pressure data for ROTAX Engine Type 912 and 914 (Series).pdf
Edited by dholly
