Avid Model A Rebuild
73 posts in this topic
If you drop one blade, (from 3 to 2) you probably don't have enough pitch adjustment without changing the gear ratio.  Ed,  an IVO uses the same hub, 2 or 3 blade.  Spacers are used to make up the difference between 2 and 3 blades width.  JImChuk
What I like about the Ivo prop is if you have a 3 blade and you ding one you can change it to 2 blade really easy
Don't you have to have a 2-blade hub to do that?  You could do the same with Warp Drive and 2 hubs.  EDMO
Ivo uses the same hub i believe.There are spacers needed. Thrust issues may be a issue with the ultralight model, I think the medium model would do ok repitching......
more pics..........found some red lawn chair cushions at Walmart....Elevator trim servo works great. digital readout on the display 1000 to 2000, 1500 worked out to be direct center.Controller is a servo tester.
Well i dont know what price to put on the parts. About only thing i think i could use is the Avid wings and wing tanks on my KitFox. The rest is not to useable to me and fuseloge still has one control stick in it (Leni got the pass side one) hahaaaa if u need stuff let me know and we can talk.  (907)460-9591 call or text bucky
 Jim is looking for Avid parts
Got the prop installed, Attempt to rebuild carbs....come to the conclusion Mikuni pump carbs suck.....My motor mount is probably not sufficient....anyway, it did run!
VID_20180324_191107.wmv
I wouldn't go that far ha.
I think its the engine design we had one of those engines local on a kitfox. It flew twice and both times the # 1 piston melted. Didn't want to say that earlier because I was really hoping yours would be a turn key machine. Those engines have gotta be out there flying. Some one must have figured it out by now.
 engine engine in prop on plane running. Carbs aren't worth a damn. But engine runs. I don't think motor mount will be strong enough
 Hirth made a lot of those f30 engines. I think most were the two carb design which I think would have a whole lot less issues. I believe I'm going to try to modify and have one single carburetor. Matt at recreational power has a lot of parts for the f30. For individual carburetors I think is a really bad design for a 2 stroke
Edited by fillmanw
I have even been thinking of an aftermarket fuel injection.
Fabricated exhaust .....Changed the four carb  setup to dual carbs.  Seems to idle much better. Got some brain storming to do to figure carb heat.....
Really, really nice build sir. Kudos as well to most excellent photos and updates of your progress.
May I suggest (if you've not considered it already), replacing the inadequate 1 leaf tail spring and updating to a 2 or 3 leaf tail spring.  www.wausauspring.com offers a nice 2 leaf and supplied to the early kits back in the day I believe.
I have the extra leaf. Have considered installing it.
Latest Update....Left wing finished with new fiberglass tank!
trying out the fuel tank....
The first pic is the right wing, Getting started on it!
Hey fillmanw,
I have installed an electric carb heat on my dual bing carbs..light, easy to install and can be left 'on' without power loss....
Have a look here
http://www.aircraftgraphix.com/jabiru carb heat.htm
Hey fillmanw,
Have a look here
will do, was wondering how ill tackle this...
Engine running on new fuel tank. Don't really like the centrifugal clutch, it sure is rattly sounding. Going to have to turn my idle up a bit!
FB Link, Cant upload, file to big....
Edited by fillmanw
i have no knowledge of Hirth engines. At idle I thought it sounded like a radial engine. I thought it was exhaust but when you powered up it sounded like a 'normal' engine does. Hard to get an accurate feel for tone in most videos but it does sound like it runs very well. Now I wonder if all clutches are noisy, I have no personal experience with those either. Good progress!
sounds really good. Also sounds like it swings that prop well. Lots of power there gonna make a back country monster.
This is an AWESOME build, can't believe I just now saw it. I'm down in Valdez, would love you check out your plane sometime. I'm curious about the heads, looks like they are clocked a bit off? The head bolts look symmetrical. Wondering if they weren't meant to have the cooling fins flat so the air can easily go across them. Only other concern with it other than cooling would be if the combustion chamber is designed with the porting in mind. Anyway great job, I've also been looking at Hirth engines and have been hoping someone up here would get one I could check out.
Ken
Ken
I looked at rotating the heads to make the fins run horizontal, no can do, , they arnt square, id have co cut them.
