503 Motor plate
In the near future I'm going to need a plate mount for a 503.
Anyone out there have one there not going to use?
AKflyerbob
AKflyerbob
For Kitfox or Avid?   Are you wanting the whole mount with plate, mount without plate, or just the plate?  Isnt the 532 mount the same?  Does it use the same plate as 532 but bolt holes for engine different?  I think I have drawings maybe for both.
Bob,  I may have what you are looking for, if it is for Kitfox.   EDMO
Sent drawing by PM.   The drawing is not to scale and must be enlarged.   EDMO
I built this one and never used it, Not sure it would be worth selling, I only have like 10 bucks in the aluminum plate, A band saw and a sander makes them quite easy,
I've got a SkyRaider plate available for a 503. The outer engine mount holes are about 6.75" x 9.0".
Came with my project as the original plate used for a time before changing to a plate that moved the engine forward a bit to fit a starter between the engine and firewall.
gunderson sent you a message
Hi Gunderson,
I am looking for a plate for the Ridge Runner 3 and think yours might be a close fit. However, measuring my engine mount holes C->C I get 6"7/8 and 8"7/8 respectively. And I need to take a look at the starter configuration on the 503. I'll get back to you, if it looks like its the one.
