Just picked up this Model 1 kitfox
115 posts in this topic
Edited by Durham66
Welcome to the forum! I saw that bird on barnstormers a while ago but So Cal was just to far to go get it, the asking price was reasonable for sure. If you don't already know there is a photo album and a little info on the original builder over on the other KF forum. Good luck with your new flying machine! Mike
The adverse yaw is mostly because it don't have differential ailerons.  Kitfox makes a control kit to make it better - not sure if it fits the Model 1.   You are correct that the tailfeathers need to be made larger.   EDMO
That would have to be one of the best colour schemes around,just install a 582 and go have some fun! A 912 is around 50lbs heavier which may be a problem for an early Fox.The adverse yaw is something you will quickly get used to.
Just get used to using your feet!  Lead your turns with a bit of rudder.  Have a good slip indicator and do what it says.    STEP ON THE BALL!  :-)  JImChuk
Yes, that looks like the correct exhaust
ok guys thanks for the replies, I've read just about everything on kit fox forrums so I feel like I know allot of you already. Wow I must say I was taken back sitting in this thing today. having only flown in 172s it's a little bit of a shock sitting in this kind of machine lol. I imagine you feel more like you are wearing the airplane. Im going to need a fair amount of tailwheel time before I'm ready to fly this kitfox. looking through the pictures of the build process I came across pictures of N85DD which I've seen on these forrums talking about the modifications done. hopefully I can achieve the same kind of success in restoring it. Thanks for the replies and I'll keep posting pictures of my progress.
Really? I'll have to check that out. Thank you!  I ended up paying 5,500.
The elevator is getting stuck right here in the picture it's seems to be all gunked up. has anyone experienced this? is oil or lubrication used to make is move smoothly when you control the elevator?
Edited by Durham66
Mine have all been greased by the builder - never had a problem.  Manuals say to grease the tube, but no specific grease listed.  BTW:  There was a Manditory Sevice Bulletin on adding triangle sheet metal pieces to the elevator where the trailing tube connects with pivot tube.  I think it has been posted on this site too.   EDMO
What is on the main portion (non-shiny) of the tube, paint perhaps?   I use Sailkote and works great.  Its a dry lube that holds up very well..
yeah It is paint. is this tube supposed to be painted? I guess it doesn't hurt anything as long as it's not where it meets metal on metal. There is no inspection plates near that section on the fuselage that will allow me to get to it. I guess I'll have to add one? any tips on how to do it.  another thing I noticed it that the bunjees for the landing gear are in the way of the flap handle. I'm guessing whoever installed them wrapped the bunjees the wrong direction. There is some surface rust on the control surfaces. the flapperon is damages in one spot on the corner. should I just use some glue to fix this? it has a Maule tailwheel. 20170603_114555.thumb.jpg.3fef00da622683 I need new Laxan. I think I read that you drill the revets out with a small drill bit?
Edited by Durham66
Thanks for the heads up
My tube is painted with epoxy chromate primer. I lube it and the bearing at every annual with white lithium grease.
I see you have the Grove aluminum tailspring. I have one too and you'll find that plus the solid Maule tailwheel make for a jarring ride if you hit cracks in the pavement. I recently upgraded to a Matco pnematic tailwheel and it's smoothed the ride appreciably. Many will warn you away from the Maule.  I'm one of the lucky few who didn't have any issues with it other than the harsh ride.
I note some of the steering chain components look non-aviation grade. Might want to revisit that.
Adding an inspection ring it pretty easy - glue down a plastic reinforcing ring http://www.aircraftspruce.com/catalog/cspages/inspectring.php cover it with some pre-shrunk fabric using polybrush, finish....
I would highly recommend buying the polyfiber book - the cover this sort of thing reasonably well. http://www.aircraftspruce.com/catalog/bvpages/polyfiberCover.php
it does seem very stiff, that wheel is like solid rock.   Thank you for letting me know about the home depot chain on here, it's hard to identify for me without the experience.  should I add a insp section plate on the  belly if the airplane to get at the elevator tube?
Edited by Durham66
Nice work on the model one I had a blast building mine, should make a fun airplane for ya.
If your paint is polytone, and I suspect it is, here's how to install an inspection ring on a plane that is already painted.  Bond the ring down with poly-tack.  When cured, cut out a circle inside the ring about 1/2 inch smaller than the diameter of the ring. Then make a series of radial cuts in the fabric to the edge of the ring.  Fold these fabric tabs back over the ring and glue down with poly-tack.  This will strengthen the mounting of the ring to the fabric without creating a large area that would need to be repainted.
I installed one on my belly under the elevator tube bushing when covering but when doing my first annual inspection I found I needed two hands to clean and re-grease the bearing.  I then installed the second inspection ring.
On the flap controls rubbing the bungees.  A fellow here in Ellensburg has a Kitfox model 2 with the same problem.  He put a tie wrap around the whole cluster of bungee wraps and that small section of verticel tubing on the right side of the bungees and sinched it up tight enough to pull the loop end of the bungee out of the way of the flap rod.
FYI, here's a photo what they did on the model 4 to fix that flaw.
Edited by tcj
I just noticed your bungees are wrapped around the top tube on the truss.  I think they should be down on the short section of horizontal tubing like in my photo above.
I was wondering about that too - What happens when you put the FG seat in? - It will sit on the bungees instead of the crosstube.   EDMO
I hope I can get mine to look as good as yours,, that jaburu would be nice too!!! i' d have to do a full tear down to get it that nice..
lol shows how little i know at the current moment. the previous owner had it like this. what weird is there are cuts in the fg seat to allow the bunjees space. I wonder why he would do that. I need to investigate more.
i didnt notice that!! idk why the previous owner did that maybe it allowed him to use different bunjees? there are cuts in the seat to allow him to do this.
