Bing carb top adjuster/90 degreen tube
4 posts in this topic
Attached is a picture of the top of my Bing 54 carb. You can see that the 90 degree tube was added but it fits into the top of the original cable adjuster. The brass tube does not fit tight into the adjuster and has worn the brass adjuster clear through the side. There is an adjuster on the other end of the brass tube. This does seem like the proper application of said parts. Anyone have knowledge of this setup or have pictures of there setup I van refer to?
Thank you
Vance
I think that's quite normal. Put a little silicone in there and then the correct rubber boot on the top. I believe JBM makes a fairly good one the rotax ones are junk.
Mine are different.  Only 45 degree and they're threaded in with a locking nut. I believe I got them off a moped site.  The only drawback is I can't extract the cable with the ferrule intact.  I made these cables up custom for my installation.
Bing_45_deg_adjuster_tube.thumb.jpg.496b
