Hurst Airheart 150 brake calipers
5 posts in this topic
I am working on the mains today and found these calipers. They have kind of a weird mounting as they just float around on three pins. Anyone else use these? They seem like the could bind up and cause problems. Mike
Edited by ppilotmike
spelling
I have never seen those before, but they probly wont bind up any worse that floating on bolts I wouldn't think.
I had them on my model 1 before I built my bush gear. The only problem I had was a shacking of the puck when it was worn a bit. The only other problem is puck replacement availability.
I have them on my Q2 and they work just fine.  Last I knew parts were available from several sources but I ordered them direct from Airheart.
Here is a link:
http://www.airheart-brakes.com/
Edited by wypaul
added link
Those were the brakes that came with the Kitfox 1. Mine had them but I replaced with later style.  Also were on the other Kitfox 1 kit I had.   I have some paperwork for them somewhere or maybe I gave it to TJay.  JImChuk
