Page 1 of 1
Parts Suppliers for Avid and Kitfox
#1
Posted 31 May 2007 - 02:40 PM
I would like to get as many links as we can to help people out who are looking for Avid or kitfox (or any homebuilt/experimental) suppliers.
Airdale http://www.airdale.com/
Kitfox Site http://www.kitfoxaircraft.com/
California Power Systems http://www.800-airwolf.com/
Blue Sky Aviation http://www.blueskyav...et/catalog.html
Mippi Ultralights (kingfox tires) http://www.mipowerpa....com/Tires.html
Wing Tanks http://wingtanks.com/
Aircraft Spruce http://www.aircraftspruce.com/
Leading Edge Airfoils http://www.leadingedge-airfoils.com/
Matco Wheels and Brakes http://www.matcomfg.com/
JMB Rotax Carb Sockets (dont crack) http://www.geocities...tips/ROTAX.html
Carlson Aircraft. Supplier for streamline Aluminum tubing for float mounting etc. http://www.carlsonai...com/struts.html
Williams Aviation http://www.murlewilliamsaviation.com/ <this link does not have any bugs in it as of 11-19-09
#2
Posted 31 May 2007 - 06:33 PM
I've had my eye on this fuel flow product for a while but I cant find much mor info on it other then what "Spruce" has to say.
Any more info, experience with, or links would be appreciated
http://www.aircrafts...s/fuelmizer.php
steve
ps. I hate the look of the gauge..., but whatever.
steve
#3
Posted 31 May 2007 - 06:47 PM
http://www.boatersla...m/fuelflow.html
Steve,
I have seen several guys on the list that used the flowscan. That is the nice thing about experimental.. we can use parts that are not PMA/FAA approved. I remember that the guys that had used them loved them and did not have any problems.
http://www.boatersland.com/f210.html
This looks interesting..you can make it a part of the preflight to punch in how many gallons you have onboard and it will keep track of fuel burn and give you a low fuel alarm.. and it is cheap! I changed my mind from the flowscan and I think I will give this one a go.
Steve,
#4
Posted 31 May 2007 - 09:00 PM
I like the looks of yours better.
A concern I have revolves around this type of situation:
http://www.aaib.gov....urces/Europa_XS,_G-IOWE.pdf
Main concern.....
"The fuel flow transducer was fitted in the single fuel supply pipe to the engine. The design was such
that there was one path, with no bypass facility, for the fuel to pass through the transducer. The
dimensions of the inlet passageway were of a size and shape susceptible to restriction or total
blockage by small debris particles"
So it would seem that a built in bypass system would be the best bet. It dosn't mention what the sender is like... I'll look into it.
http://www.northstar...anuals/F210.pdf
steve
Main concern.....
steve
#5
Posted 31 May 2007 - 10:37 PM
I just read the manual on it. It only states that you need to have a filter before the ducer so you dont clog up the gauze filter in the transducer as that could lead to engine damage.. So I thinkthe best bet would be to install a bypass line and a valve you could hit real quick if it starts clogging inflight....
Of course..while everything mechanical can and will go wrong at one time or another, how great is the risk really?? I have the screens in the tank, a filter on each tank before the gascolator, a filter after the gascolator and one after the fuel shutoff / tank selector valve..Any shit gets through to the transducer, and I have not been looking at the see through filter in the pre-flight...
I am not sure it would really be worth putting in bypass line... I dont have a spare engine behind the seat just incase my rotax gives out on me....There can be many trains of thought on this one.
#6
Posted 16 February 2009 - 06:09 PM
#13
Posted 02 December 2009 - 03:31 AM
I got this email from Brett at Airdale, guess he is doing business,
anyone with orders should be getting filled soon.
Hi Robert,
Your package went out today. The tracking number is 9146875 10603.
Your invoice will follow in the mail. Thanks for your order.
Brett
Hi Robert,
Brett
Avid Catalina being rebuilt as you read this
Kitfox Mod 1 582 Brolga 68" "super rocket"
Kitfox Mod III 582 hanging in the garage waiting on motivation
#14
Posted 05 December 2009 - 05:41 PM
Hi Robert,
Brett
Hi Robert,
Brett
ADD on
Parts arrived in good shape
Hinge Rib tails (12)
Root ribs (2) for the Catalina
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
