YAMAHA RX-1 (140 HP) install in Kitfox 5
109 posts in this topic
RX-1 IGNITION :
Been waiting for the mount to come back from the welder, so I've been digging into other things on the plane.
One is wiring ignition power to the ECU.  There is a single wire for that and I believe it is the only power source to the ecu, making it critical to keeping the engine running.
I decided to power it from two sources, each switched and CB protected.  One source will come directly off of the engine magneto (alternator coil), prior to the main fuse for the charging system.  The other power source will come from hot battery direct. I will put a surge protector on the magneto side in case the engine's voltage regulator were to fail.
I will also will diode protect each power source to prevent backfeed if I get down to one source (example that if the magneto were to fail I would want to switch the master off to conserve the battery, but would not want my panel being fed backwards through my ignition hot battery wire).
So that is my plan.   Any electrical engineers out there (or just people smarter than me!) please speak up if you see me going wrong!
Edited by MN Kitfox 2
How is the project coming? Do you have a list of thing you took off the sled ? A motor and computer purchase , or should I buy a complete sled?
LOW VOLTAGE ALARM:
Since the RX-1 ECU needs a power source to keep the engine running, I put in a low voltage alarm in to warn me of any battery / charging problems.
The low voltage alarm has two leds, green when above threshold, red with loud alarm when below.  Threshold can be set to any value with a smal pot adjuster.
I put it and a voltmeter into a 2" round instrument hole and set the alarm to 11.5v
All for only $5
As far as buying a motor, I have always thought that getting the whole sled is best.  That opinion is strongly biased since I live in snow country with sleds for sale all around me.  Here are my 3 thoughts for buying an entire sled:
1.  You can give the motor a little run time, pre-tune it, and make sure it isn't about to throw a rod or something.
2.  You'll have the following extra components:
Airbox, oil tank, oil lines, thermostat housing, coolant overflow, coolant hoses, exhaust flanges (flex type), wire harness, ECU, voltage regulator, fuel pumps, starter solenoid, and a few others that I'm forgetting here and will edit in later.
Some of that stuff you will use, some you will not.  But it is really nice to have a pile of options to work off of and modify to work.
And 3,  you will have a reference on how all the little things are set up and routed (like carb heat lines, oil lines, ect)  Hopefully this build thread will detail all of that as I go, but there have been times where it has been nice for me to run out to my RX-1 snowmo and peek under the hood as the "cheat sheet"!
But there is a ton of work parting out a sled!  So if the right deal came up on a motor, you'd just want to make sure you plan some $ to ebay up any missing components that you might need.  And that is a great thing about the Yamaha:  parts are plentiful and cheap!
Wish you live closer. Understand all the little parts, I have done a couple repowers.
How did you get the primary drive off of the rx1 ? I tried the water method and a 4in 3 jaw puller no luck , what is the secrete? I was thinking of renting a bigger puller.
you will need a clutch puller, Any sno shop in your area should have one that they will pro let you use. If not let me know Im sure I have one I can send you, that is if its the same one as the old two strokers use to use, which im sure it is.
This is what they look like. If you try anything else you'll probably end up ruining the primary clutch. You just thread it through the primary and the smooth part goes into the end of the crank and pushes the clutch off the shaft. Don't use a cheapo one because the can bend and get stuck inside the crank.
https://www.ebay.com/itm/YAMAHA-PRIMARY-CLUTCH-PULLER-SNOWMOBILE-EPI-PCP-6/280613120505?epid=654827600&hash=item4155d869f9:g:qtEAAMXQvJVRRzno&vxp=mtr
Ken..................
OK,  I've got a couple updates here that I'll copy over from the Facebook group.
First I'll post up some conversion tips I have learned from those who have built and flown the Yamaha, then I'll post up my (slow) progress in my build.
CONVERSION AND TUNING TIPS, Yamaha RX-1 engines
Airbox considerations:
The snowmobile airbox is large and difficult to fit under a cowl, but when it is used, the RX-1 jetting (135 mains) and setup is fairly close to final tune.
Typically, smaller custom airboxes are made and, generally speaking they tend to run leaner... requiring larger jetting (up to about 180 sized) to achieve the correct air to fuel ratio.
An airbox is generally needed to buffer under cowl turbulence and allow for consistent pressure across the carb rack (RX-1).  Individual filters on the carbs have been reported as highly problematic, especially at higher speeds /  cowl pressures.
Carburetor venting (float bowl) needs to match internal airbox pressure and not the under cowl pressure.  This is typically done by running venting inside the airbox.  (See note below)
Also the crankcase breather is vented into the airbox.
It should be noted that when rerouting the float bowl vent lines into the airbox that you should have a way to allow for fuel overflow to exit the bottom of the airbox.  I have seen a stuck float in sleds where quite a bit of overflow comes out of those vent lines and you would want a way to evacuate that excess from the airbox and route it to a safe exit point.
This airbox exit will also serve as a oil exit if any were to "burp" through the crankcase vent line in the airbox.
I ended up going with an airbox off of the Yamaha R1 motorcylce (same engine block as the RX-1) and will make a seperate post on that.
Header construction:
I chose a custom header from a pvc mock up kit that I will do another post on below.  (Pic of my mock up below)
Header primary tubes (prior to collector) need to be as long as practical (24"+ ideally) and as equal length as possible.  A 4 to1 collector is common in the R1 motorcycle header, snowmobile exhaust (which is later split to dual exhaust) and aircraft fabrication. 4-2-1 designs have also worked very well.
The primary tube ID on the RX-1 is 1.28 and 1.38 on the R1 (which uses an EXUP type valve in the collector to "choke" at lower rpms).   So there is a 1-3/8 size that is ideally used (It can also be found as a 35mm metric size).  It comes out to a 1.37 OD and about 1.32 ID.
Keeping proper tube dia, long (and equal) primary length, and smooth inner tube transitions will help throttle response.  If you try to deviate from those things too much your run quality will likely suffer.
Modding headers from other vehicles:
Using a pre fabricated header off another vehicle can work well for non-cowled applications.  For planes with a cowl, I found that the rework on any of these options outweighed a full custom fabrication.
Some people have successfully used motorcylce headers such as from the  R-1 motorcycle and  07-08 gsxr 1000.  The motorcycle headers run about $50 on ebay but are sometimes made of titanium, so modifying them can be problematic.
The 1990's Honda Civic headers have identical port spacing and are avail for $60 in steel and stainless steel but the tube diameter is a smidge on the large side which makes the "step up" transition from the snowmo flex flange output a bit problematic and there can be a little bit of throttle lag / hesitation when using tubes that are too large.
Suzuki samurai headers have also been used and line up well with the head, but like the civic header they do not bolt right up, so you have to cut them and weld in a flange adapters.
If I were working with the civic or samurai header I definitely would buy the one piece header flange (with stubs) for the yamaha 4 cyl from GP Headers to save a ton of time and frustration getting these headers matched up to the head.
www.gpheaders.com
As far as mufflers, I am using a 2012-14 gsxr 1000 muff
For those of you that  have the yamaha three cylinder you can use the yamaha yxz 1000 side by side header pipe . Same engine nice long sweep headers that curve down.  (See pic below)
Tuning with the AFR guage:
Some guys here know a ton more about the afr guage than I do, and which one is best to buy.  I'll leave it to them to post up their opinions.  But generally speaking, my notea show that we should be looking for Air to Fuel Ratios of about 18:1 at idle, 13.5 for cruise, and a little richer for WOT.. about 12.5 to 13.0
Teals note:  I have ran a few RX1 aircraft and noticed that a leaner idle (17-19) seems to work really well. I have found that if i set the AFR at 13-14) at idle it will have a little rough spot around 4500-5500 rpm.
RX-1 Jetting
Ok.  The RX-1 uses altitude compensating Constant Velocity  (CV) carburetors.  I'll let an expert explain how they work via the vacuum slides (yamaha calls them "piston valves") in front of the throttle butterfly, but generally speaking the vacuum slides have a spring that can be changed for tuning purposes, the main jets can be changed or drilled out to enlarge, the needle position (in the vaccum slides) can be raised and lowered, and the idle mixture adjustment made via a fuel screw.
Alternate vacuum slide springs  and main jets are available from Holtzman (Steve Henry's setup uses the blue colored Holtzman slide springs)
NOTE THAT IF YOU CONTACT HOLTZMAN, TELL THEM YOU ARE TUNING A "SNOWMOBILE"!  They don't understand experimental rules and are a little nervous about supplying parts for aero use.
http://www.holtzmaneng.com/carburetion-products
As far as drilling main jets,  If you have a full drill index you can open your jets up. A 135 main jet is 1.35 mm in diameter or .051"
Teals note:  These carbs have 3 jets. A idle jet thatvis normally a 17.5 (.175 mm) a main jet  (stock is around 135) and a starter  jet (choke or enficher circuit). The idle jet is used up to about 1/4 throttle then the the needle positioning inside the the needle jet sets mixture. As the slide rises and the needle rises out of the needle jet (needle is tapered so the more it is pulled out the more fuel can pass) the more the main jet controls mixture. The main jet controls mixture mainly at 1/2 throttle and above. More so at 3/4 to wot.  The needles have 5 positions just like most other carbs. Needle position is used for midrange tuning. There is also a screw on the bottom of the carb that sets air fuel ratio at idle and just above idle.  One other thing ive noticed on a number of RX1 carbs ifs that idle jet is opened up. Im not sure if by normal cleaning or drilled. The hole in the idle or pilot jet is tiny at 17.5 (1.75 mm or .007" in diameter). One way to tell is to measure the cleaning wire with a caliper and see how it fits in the jet. Ive found that running these engines with opened up pilot jets causes a slightly rougher transition to the midrange and doesnr idle as smooth. Also this jet doesnt have anything to do with what airbox your using because at what throttle position that these jets are being used at the slides are causing the correct back pressure. Unlike when the slides are opened up at higher throttle settings and there is a lot of air flow through the airbox.
FUEL TYPES:
The Yamaha manuals call for a min octane of 86, and use of fuel with ethanol up to 10%.  That ethanol content may not, however, be suitable in many aircraft fuel systems.
As far as 100LL, the three main concerns are in lead contamination on the valves, O2 sensor (if equipped), and oil.  The screenshots below are  advice from members here about the lead problem, but it should be noted that no problems have been reported in occasional use of 100LL (when that is all that is available) from flyers of the Yamaha.
Consensus here probably being:  If you run avgas (100LL), do so sparingly and remove your O2 sensor when you do.  If you run it more often, use the appropriate oil, plan oil changes more often, and use additives in the fuel that help reduce lead deposits.
Running it exclusively is not advised, but no one has yet found the exact results in doing so.
Edited by Yamma-Fox
Update sept 2018
R-1 AIRBOX OPTION for APEX / RX-1 CONVERSIONS
I ended up going with an 04-06 R1 motorcycle airbox.  It is a nice small box that is available for about $35.  (I need to credit "Yooper Ed" for finding and proving out this airbox... Thanks Ed!)
The small problem with this airbox is that the 4 holes are spaced a little narrow, so I came up with a plan:
I'm gonna use the snowmo airbox carb boots and sleeve 2" pvc into them and then into r1 airbox.  I'll need to use 2" CTS (copper tube size) PVC which has an OD of 2.1", which should be a nice snug fit in the carb boots.  Standard 2" PVC has an OD of 2.37 and will not fit.
A little spin and flex of the carb boots should get the pvc lined up to slip in the airbox.
Below are some pics and videos of my R1 airbox. (The second pic shows a comparison between the snowmo box (in front) and the R1 box I used.
UPDATE ON FINAL JETTING FOR THE R1 AIRBOX:
Main jets drilled out with a 2.10mm drill bit
Needles set leaner, clip position 2 (2nd slot from top)
Pilot screws 1.0 tuns out
Plugs are upgraded to NGK CR10EK
Video #2 of my airbox, now complete with Frogzskin hydrophobic mesh prefilter:
Edited by Yamma-Fox
Jetting update
CUSTOM HEADER:
I had a great experience with an outfit here in MN helping me build headers for the Yamaha!
I first looked at trying to rework some auto / motorcycle headers but quickly learned that for a unique "one off" application that has to precisely fit under a cowl, you really have to go custom.  So then you have two options:  1. DIY using auto parts fittings or 2. Go with the GP mock up kit which allows the following advantages:
1.  A totally custom header design.  With the mock up kit you have virtually unlimited options as to the routing, design, and output of the header. The guys at the header shop have a lot more options than you can find at NAPA!
2.  Professional fabrication.  This guy does this exclusively... all day and every day.  Top notch materials, processes, and weld quality will pay off down the road and is definitely worth a few extra bucks IMO.
3.  Your choice of material.  From mild steel, 304 sst, and 321 sst.  Price estimates were approx $900 USD for mild steel, $1200 for 304 stainless and $1800 for 321.
My build was out of 304 and came to $1240 (with everything included).
Below I will post up some pics of my build with the GP mock up kit.
Pic 1 is of my pvc mock up with the GP kit.  It only took a few hours to make!
Pic 2 is the one piece CNC cut flange that GP made up for the 4 cyl Yamaha motors (note that it is made for the mock up kit with internally threaded stubs and obviously not the one used for final fabrication)
Pic 3-5 are the finished product.
https://www.gpheaders.com/products/custom-headers/
Nice!
I wonder whether some exhaust shop with a talented guy and pipe bender could make up a set for the 4 cyl. using the mock up kit and flange. Wouldn't hp and tune benefit from smooth tubes into a collector vs. welded pieces?
Yeah the internal tube has smoother transitions than what you see on the outside.  And ideally that would be more of one piece formed tubes like you see when they do big production runs on something like motorcycle headers.  But I suppose for a "one off" this is about as good as one can expect.
I don't see your oil cooler location yet.
The Yamaha oil cooler is integrated on the side of the engine next to the oil filter.  It routes engine coolant through it to do the primary cooling then oil also goes to the large remote tank where it is cooled further.
So no addnl oil cooler like the 912.
As for my external components, I'm putting the oil tank fwd of the header where ram air comes in the cowl, my belly radiator will likely get moved under the engine with an aux fan, voltage regulator + starter relay on the engine mount, and on the firewall I plan to mount the fuel pump and coolant tank.
Behind the panel I have the ECU.
Edited by Yamma-Fox
THROTTLE REVERSER:
Since the yamaha snowmobiles use a "pull" throttle, there is a need to reverse that to a "push" for aircraft use just like the 2 stroke Rotaxes.
Yet another big thanks to Steve Henry for sharing his ingenuity.  This time on his panel mount throttle reverser.
Steve also sells these at a very reasonable price.  When I counted my time, welding, and materials, I was none ahead in doing this myself, but was itching to work in the shop today and knocked this out.
Pic with tape measurer is the one steve shared, other is my copy ready to send to the welder who will cut my throttle control hole and tig up 3 places.
And YEAH, my "rivet in pivot" is temporary!
My throttle cable "cylinder " hole will get drilled through other half after welding (pic below).
Also the spring in pic above is obviously there to balance out the throttle return spring on the carbs / throttle bodies.  I got one at ACE hardware that was strong enough to naturally pull to about 3/4 throttle, which under some failure scenarios would leave me with some thrust in the air.
OIL SYSTEM ROUTING (RX-1 and APEX):
Reference the three labeled pics of the oil system  (below).  Routing is as follows:
A goes to 1
B runs up and "tees" to both 2 and 4
C goes to 3
COOLING SYSTEM ROUTING:
Reference the pics below of the cooling system components where each port is labeled.
(NOTE: Pics are of an RX-1.  As I understand, the APEX should be the same except it would not have C1,C2, or H2 connections.)
The matching connections are listed here:
H2 goes to C1
H1 to 10
X2 to 14
X1 to J
I to the engine block below the headers
H is cold feed from radiator
13 "T's" into that cold radiator line connecing to H (13 is a cold engine bypass route (bypassing radiator) when t-stat is closed, see hand drawn diagram below)
11 is Hot outlet off expansion tank (white tank in my pic) which goes to hot side radiator.
C2 to K
B1 to L
12 is unused, and can either be capped off or drilled out and tapped to 1/8 NPT for a coolant temp sender (note that aluminum is thin for tapping, so take caution if you choose to thread it)
Edited by Yamma-Fox
CRANKCASE BREATHER:
The crank breather is labeled in the bottom pic here and it  this is connected with a hose to an oil "trap" (top pic) and then typically routed into the airbox, but some people have reported just running it to a negative pressure location (non ram air location) with a filter at the end of the breather hose.
Edited by Yamma-Fox
Y- Fox... you are the man.
I would first like to thank you... for posting all the info on this project. Many little specific things...add up. You are helping GREATLY ( "I" don't have to look this stuff up)
Next...I would like to add....I am back. I took the summer off...Went on a couple of long motorcycle adventures...fished...played golf...All that retirement stuff.
Now...bought a new TIG welder.....decided to do EVERYTHING myself....Really enjoying the work. Have the motor mount
almost done and finished welded. Getting ready to start the exhaust. Working on a positioner...to improve the  tube welds.
One question...how tried is this R1 airbox?  I built a big ugly motor mount...to accommodate a big ugly airbox (why re-invent the wheel..I thought)
I looked at those  R1 airboxes early on...and would have gone with the 2002-2004 model which looked like a small version of  the (big and ugly)
Now...after seeing yours, I have ordered one..to check it out...How does the jetting compare to the big and ugly? I was trying to avoid massive re-jetting.
Posts to follow soon....John O
Thanks for the thanks!  I'm just glad if I can help other people out (half as much) as I have been helped along in this project!
That R1 box has only been used by one other AFAIK.  That is "Yooper Ed" here in the group, but he doesn't frequent the forum often.  According to him, it merely required a jetting change (he drilled out his main jets to about 180 size) and he says it runs great.   His info is why I chose the R1 box but if you have room you that snowmo airbox will work great as well.
But as far as the jetting / tune, no matter which airbox you choose,  you will have some fine tuning to do and really should run an AFR guage to get precise jetting for your particular setup since it seems each plane runs just a titch different due to ram air effects and exhaust system differences.  Just be  sure you dont run avgas on the AFR's O2 sensor!
Hey, start up a new post with your motor project!  I'm really looking forward to seeing it come together!!
Edited by Yamma-Fox
Getting ready to put all my pieces together!
I finally got my big parts together, ending today with getting my mount back from the welder and powdercoat guys.
Below is a pic of the "big 4" custom components in a Yamaha conversion:  Motor Mount, Airbox, Header, and Throttle Reverser.
Anyone else following in my footsteps will have an easier job these days because we have a lot of people in the Yamaha community who have stepped up in offering help with these and other fabricated parts.  For more info, including contact info for FWF parts, join up in the "Yamaha Aircraft Conversions" Facebook group.
few that looks like a nice mount. Did you save the jig for making more?
Proud of you!! :BC:
Thanks guys!
I didn't use a jig, just built off the firewall with oversized tube (3/4") at the bolt up locations to allow for a little warpage and got lucky... things only moved about 1/4" so those small mounting bolts are just a little offset in the 3/4 tube.  I will custom grind some brass bushings to fill the "eccentric" gap (see photo of the off-center gap below).
I really wish I could scan this thing to a file in order to share it for anyone else with a KF 5-7, but I just don't have acess to something like that.
