Bing 54 ?
5 posts in this topic
Are the clips suppose to be split like this or do I have two broken ones? The needles on both of my carbs are super sloppy fits in the clips even with the o-rings. I do not see any appreciable wear on the needle grooves. Mike
Answered my own dumb question. I forgot that I have two new bing 54's for the 582 so I disassembled one of them. The clips are normally split. Lots of wear must be the culprit on both pieces. The crumby part is I only want to use this engine for a couple hours and at the rate I am moving maybe not at all before converting to the 582. Mike
Edited by ppilotmike
Recommend replacing the needles every 100 hrs or so and make sure you have the newer style that contain the little O ring on them to keep them from rattling.
Needles and clips coming from ASS. Mike
I get my parts from ACS, but to each his own.....:-)  JImChuk
