Best prop for a 532/582 with an A/B gearbox
3 posts in this topic
I think I am going to have to buy a new prop for my little Kitfox. It has a 532 on it now with an A gearbox. I have a new 582 greyhead I will eventually put on it which has a B gearbox. I think I am more into smooth operation over performance so I am thinking three blades. I would like something that will work on both. What is the best diameter to run? So let the suggestions fly I am all ears. By the way I can not use an IFA prop because I fly light sport. Mike
Sent you a private message.  When I was trying different props on my Kitfox 1, I didn't really notice much difference between the 64" 3 blade IVO and the 68" 3 blade IVO that I tried.  The 2 blade 70" taper tip warp drive was better than both for performance however.  Not as smooth though.  JImChuk
I run a tapered tip 3 blade warp drive and it's pretty smooth . I'm sticking to that set up it works great.
