Step 2, Build Magnum!!
201 posts in this topic
On to the paint booth for the fuselage! No more fabric or tape to install! Whew..........
Looking good Barry!
Leni,  I am never against experimenting - I don't have any info that says the flat plates help STOL better than other tips.   It certainly wouldn't help if it makes the wings shorter by 2 regular tip-lengths.  I have studied this subject a lot, and believe the most important thing for STOL is wing area, profile, and VGs.   The short-wing Pipers proved that squared Hoerner-style tips helped them get off the ground quicker than the round tips because it added wing area.  I would like to see some positive results comparing the flat plates with other tips on the same plane, same wings.  When someone asks my opinion, I give it.  That's all there is to this.
Remember the Kitfox with the Big Radial engine?  Guess that was them Experimenting with sales back then - so what are they doing now with the STi?   I hear that it has a thicker rib for more lift which would give better STOL disregarding the tips.
Ed,
I may agree with you on the KF tips.  The Avid tips that are actually turned up a bit at the trailing edge suck.  If you ever flew close formation with an avid you would know what I am talking about.  The vortices that come off these wings will damn near roll the trailing plane over if you are not ready for it.  The tips on an avid are really not like a full rib in area.  If you don't have evidence to support what they may do to help then why be so against it?  AS I have said many times before, when I was experimenting with tip designs on my RC models, the flat plate tips did the most good for slowing flight and lessening tip stall tendencies.
Ed,
Leni,  I am all for tip experiments.  I hope that someone can give some actual measured comparisons of same plane, same pilot, same weight, same winds, and at least two different tips.  Sounds like the Avid (Finch?) tips that turn up at trailing edge do a better job of shedding the vortexes cleanly away from the wings, making them stronger, (what they are designed for), which should help the performance of that plane even though it affects the one behind it.  Maybe they are not the best for formation flying?  EDMO
Ed & Leni,
Im going to move this conversation over to the  Avid General Hangar to get some more input and keep us from polluting Barry’s post any more than we already have...
Ron
Ed & Leni,
Ron
I thought this conversation started with Barry's Magnum?  Anyway, I am done writing about this.  EDMO
Fitting up boot cowling, floor pan and windshield.
Been gluing and fiberglassing boot cowling on. Windshield is drilled. Put first stripe on a wing today.
Fitted floor boards tonight, what a poor design.
now that looks nice I wish my fiberglass work looked that good. It took me hrs to get my cowl laid up and look some what decent.
Edited by TJay
Thanks, it is a very labor intensive process for sure.
Today was engine and landing gear installation so I can fit the front cowling to the boot cowlings.
Man you are moving a long with your project. Looking good.
Thanks Paul.
Got firewall installed today along with brake lines.
Took the Magnum outside for some fresh air today, finally doing final assembly!!
Almost ready for wings and rigging.
Status update: Got the door latches, window latches, window hangers and windshield installed. Put down some matt black vinyl on the dash too to help with glare. Will be working on panel, flaps and turtle deck while I wait on my engine parts to get checked out. I just hit the 600 hour mark, so if anyone wonders how long it takes.. Still a ways to go...............???
Skylight and turtle deck fitted. Flaperons mounted and linkage adjusted. On to engine and panel.........
Engine overhauled and installed. Time to push to the finish line!  Lot to do yet wiring panel and finishing engine install.  But getting the first flight itch :))
Been about one year since you started the build thread and you have made tremendous progress in that time. I suspect you will be flying a super nice airplane very shortly. Great job!
Thanks!
I hope to have it airborne soon. Lot of details to finish with panel and engine baffles etc as you well know.
Blue skies
It looks beautiful!
This is Saweet! I am 6ft 4 , and I think I could fit it that!
Edited by daboring
I am 6' 3 195. Very roomy, you would like it.
