Kitfox 1 Build
9 posts in this topic
Started to play a bit with the plane.  Gotta get my self back into it again.  Fit my doors and made a poster board pattern of the window also put some markings on her sure is fun to look at. And she now has a name.
Great name!  Just wondering if small letters in Experimental are 2" high - and believe the regs say "Block or Capital Letters at least 2" high - You can probably get it slid by, but depends on how finicky the inspector is.  I believe any "normal" person would be able to read it just fine.  Looks good.  EdMO
Flight reports, I want to hear about flight reports.  And flying videos to!  Looking good TJay,  keep at it and I'll get what I'm asking for.  :-)  JImChuk
Ha I had to send the file to the DAR before I had them made, He said he would accept that font. And the letters are right at 2 inches tall.
Curious if the DAR required the Experimental stickers at each door? While it would appear to satisfy the requirement, mine will not approve either a single sticker on the rear carry thru trim or one each on the inside of each door along the KF4 aluminum center trim strip. Must be on the exterior at each entry.
My KF1 & 2 had the single word hanging from the rear crossover - Now I have to go look at the KF3 to see where it is marked - I never thought to look on it.  All DARs are not made the same!  ;<)  I believe the rules also say that you have to advise the passenger of the difference between your Experimental and Factory planes in addition to having the approved sticker saying the same thing on your IP - in other words, unless you are confident in my plane, or brave or stupid, then don't get in!  Ha!  EDMO
played with the Kitfox today. After scratching my head a bunch I think I finally came up with a decent heater idea. Not quite done with it yet I need to hook up the intake tube yet.  It will take air from the front of the engine ram air duct thats for another day. As you can see from the pictures the air will flow right through the heat muff and out the bottom through the trap door for summer time operation. Pull the cable on the dash and the trap door closes then air is forced into the cabin. I also packed the inside of the heat muff with stainless steel scrubbing pads. It is all made form Aluminum so the scat tubing is about the heaviest part. Hope it works
I have 2 inch scat tube coming out of the heat muff and thinking about feeding it with 1'1/4 scat tube any thoughts on this?
There is pressure in the cowl, I get a good flow through my heater with it just being open on the front.  Another thing is the air is bound to be warmer inside the cowl then the outside air, so it wont have to be warmed up quite as much to be just as warm as outside air.  Maybe you don't need any outside air??  As far as sizes, inlet tube can be smaller then outlet tube, cause the air expands.  If my math is correct, 1 1/4" tube has only 1.227 sq. in of area.  2" has 3.14 sq. in.  Almost three times difference.  Maybe 1 1/4" is to small.  1 1/2" tube is 1.77 sq. in. of area.  Half the amount of 2".  Will the air double in volume when heated?  Then again, how much restriction will you get with the scrubbing pads?  Lots of questions that may only get answered when it's built and working (or not working)  On second thought, maybe cowl air would not give enough pressure for what you are doing.  My shroud is much larger, and has a much larger hole.  I even enlarged the entry hole after I took this picture.  I does heat very well though.  There is a deflector/air dam at the top, that forces the air to go around the bottom of the muffler, and then out the 2" holes on top.  I guess that's why we call them experimentals.   (with emphasis on the last part of the word)  :lmao:JImChuk
