26 posts in this topic
Hi,
I'm an experienced Army pilot who recently purchased an Avid Flyer Speedwing Model C, Mark 4.  I was contacted by a pair of FAA Inspectors who live in the area and were conducting ramp checks.  The gentlemen approached me while I was in the hanger doing maintenance and inspected me.  They informed me of the following with regards to my Avid Flyer experimental airplane....
1) As the private/commercial pilot operators with an A&P or Repairman Cert for myself, I am only authorized to conduct basic operator level maintenance on the aircraft.  Such as fluids, tire pressures, and minor adjustments.
2) Folding then unfolding the wings requires and writeup and inspection by an A&P in the aircraft logbook.
3) The builder (who was a private pilot) was required to place his "certificate" (or private pilot) cert # next to his name and signature for the condition inspection done prior to sale to me.  The FAA was going to contact the seller to "educate" him.
Based on what I've been told by fellow experimental aviators these statements are not accurate.  When the FAA team confronted me with these statements I replied by stating that I understood I was entitled to conduct "all" maintenance so long as the condition inspection is signed off by an A&P annually.  At the time I was replacing some fuel filters and making some adjustments to the nose wheel.  They stood by their statements.  I thanked them for their insight and lived to fly another day.
Curious what the aviators in this community think about this.
You were correct.  As the owner of an Experimental, you can do all maintenance, and as an A&P you can do condition inspections.  The builder was legal in doing a condition inspection too if he had a repairman's certificate or A&P number - He also had to do one before Airworthiness Inspection and that one does not require any certificate.  Unfolding wings does not require an inspection, as it is part of preflight duties of the pilot.  Those guys need to get educated enough to quit the BS!  Maybe read the FAR's for a change?  They probably knew that it was BS or they would have written you up on the spot!
 Nice looking bird.  EDMO (A&P/AMT)
Wild looking prop! Mfg?
Thanks EDMO :)  That's what I thought.  Chose my battle.
NR Props out of Ukraine.  Nice guy and great performance and price. http://nrprop.com
I don't like "Ramp Checkers" most of them don't know what they are doing and are bored and curious.  They ramp-checked my Ercoupe once because they didn't have a clue about it and were just nosey - At least those were polite and only asked questions like they had never seen an Ercoupe before.  The ones who checked my Cessna and Cherokee had at least read the books.  Guess there aren't many books on Avids and Kitfoxes unless you are a builder, but there are FARs they could at least read!  EDMO
They must be rejects from ATF enforcement or something.  Completely WRONG!  The quality of federal employees is at an all time low.  Maybe I should apply!  :flamegun:
Maybe we need to write a pilot's pre-flight checklist for those idiots - Maybe say, "Unfold and pin wings before takeoff"!  ;<)  EDMO
Maintenance: 43.1 B applicability - part 43 (which requires A&P, allows minor maintenance, etc.) does not apply.
Condition inspection: What it says in the operating limitations. Probably should have written the repairman cert number.
Folding wings without log book entry  - don't have a source for that, but obviously common with many models of aircraft. Is it covered in the aircraft "manual"?
To me, Folding wings is like Opening doors - anything built to hinge is designed to be moveable and does not require any other action. ???  EDMO
Nice story. Very, very similar to our experience here in the middle of Europe.
Inspector CAA/FAA are probably sort of people without borders. You can find them everywhere / and they are really the same sort.
That is the main reason why I am out of "certified category of aircraft" even with CPL and air force experience.
Yea - no argument here. The only issue would be when you run into some paperwork "expert" as the original poster...
Then it comes down to "is it maintenance" or "normal operation".  Putting a paragraph or two in a manual under a section "preflight checklist" gives you something to point at when someone wants to see paperwork.
The other argument is that since part 43 does not apply (per 43.1) then it doesn't matter if it's maintenance (as it is on my ride), and the op-lims only require that you log the condition inspection then you just do it and go on your way.
At the risk of starting a war with the local FAA guys, if you got their names, look up the FARs mentioned regarding experimentals so you know you are on firm ground, and then give your FSDO a call.  Ask their opinion as to the legality of you working  on experimental category aircraft.  If they say you can do your own work, per such and such reg, then imform them of your ramp check and the false info the inspectors had.  If they say your can't do your own work, quote the regs that say you can.  Lots of these FAA guys are not familiar with experimentals and it would be nice if they knew what they were talking about.  Not wanting to start a war with them, but in a nice way show them they still have something to learn.  If they are decient people, they will want to know what's what also.  And besides, when they are wrong, they could end up looking like a fool by pushing something and I'm sure they don't want that.  I had one FAA guy start to raise a fuss about me having done some work on the plane, and when I stood my ground on it, I could see the look of uncertainty come into his face.  He said he would look into it, and that was the end of that.  JImChuk
PS  interesting links to look at.  http://www.wanttaja.com/avlinks/MAINT.HTM
this one is from the FAA see   43.1 (b) (1)      https://www.ecfr.gov/cgi-bin/text-idx?SID=0e902e46815fd09eb9afe50a4b48988f&mc=true&node=se14.1.43_13&rgn=div8
For what it's worth...
At one time, the FAA classified installing wings on gliders as preventative maintenance. In '87 this was REMOVED from part 43,
https://static1.squarespace.com/sta...2fe131f8fb14f4b7/1464113792897/05+06+1987.pdf
Also added words in glider pre-flight (part 61) about training to install wings that have since evaporated and been replaced by just "preflight operations" near as I can tell.
So, while one can argue that it doen't matter for an Avid (E-AB) for an S-LSA the above reference indicating that installing wings is normal operation per the FAA (at least for gliders) might be a handy reference if you have to deal with a pain in the butt inspector.
I work with a lot of FAA guys and 99% of them have been true professionals, a pleasure to work with, providing valuable input and insight.
As to the 1%, they are everywhere in life I guess!
Sounds like the OP found some 1%"ers" ;) who thought they had a chance to strut their stuff.   Nicely handled by the way, no point in causing a fuss unless they started thinking they were going to hand out a violation...   then I'd take the "yes sir" gloves off and dig into the regs and stand my ground.
I have done that before and the situation quickly dissapated when they saw they were mistaken.
I would have told them to pound sand.  You don't have to let them into your hangar to look at your plane.  Tell them to go find a 135 guy to harass as that is what they are there to be looking at, not a private guy.
As for what they told you?? not even close to correct.
About time I’ve been waiting a week for your response!
Yes, if you are in your hangar, the 4th amendment of the constitution applys and you can tell them to leave. However, be warned, they can get your N number and write you a nasty letter giving you 10 days to present your aircraft and records for inspeciton. Failure to comply with this will result in suspension of your special airworthiness certificate(pink).
Its better to say OK, thanks, I have to go run some errands, I like to stay and talk, oh by the way do you have a busniess card? This way you know who they are....
1) if you are just a privite pilot , yhou can only do preventative maint. listed inpart 43 for the FARS..
If you built the aircraft(experimental) you can applly for a repairman certificate for that airplane and that airplane only to do maintenanve and inspection including the yearly condition inspection. Who better knows it than you...
IF you are not the builder, you need an A&P to do the iinspection and maintenance... The A&P can not delegate the work. IN the real world, owner do a lot of their own work and then get an A&P to do the condtion inspection...you need to be careful here to make sure you dont set the A&P up for a trap so be sure to tell him what ever you do...
WHen  the experimental is originally certified, all the paperwork and copies of the special airworthiness certificate and operaiton limiation and 3 view photos are put in a file at the local FSDO who has responsibility for that are....fact is a lot of experimental get sold and go to another area of the country.. the old folder can be forwarded to the new area, but generaly this is only done if the plane is stilll in phase 1 of test flying and you need to have a new assigend area to fly in... but most of the time the files are left in the old FSDO files...
My guess is you encounted a seasoned inspector and a new hire.. There are about a year of OJT stuff the newbie has to get thru and one of those things is a "
rampcheck"
The issue of folding the wing?? Even I am not sure on this one. If it is considered maintenance, then it would require a log entry... sounds silly dont it...I guess in an extreme situation, if you had no A&P and were not the builder, you might be able to get a letter from the FAA FSDO allowing you to fold and unfold the wing, however you would need "training from " an A&P" most likely.....THe feds are changing the rules all the time...
I can tell you this, there are no records of alterations or changes made to your plane so they dont know what what kind of instruments it has or what radios, and unnless hyou install 50" tractor tires, they dont even know what kind of tires or prop is on it....
ON a ramp check they looks for certain things. Pink special airworthiness certificate, operation limitations, placards required for experiemental aircraft, even a stupid compass card, maybe ask if you have an ELT if it is a 2 place or bigger plane...
Just do what you want, but be careful and if you are not sure aobut how to do something ,as someone, an A&P or another builders.... Ive seen a couple of planes now where red silicon was used on fuel line fitting and it got in the fuel system. so you need to be a little cautious in what you do....
Old retired FAA inspector....
\I saw one owner in Alaska chase two hot shot inspectors off his property with a [paddle!!! once.. one of the idiots got up on his new floats and ground gravel into the new paint....!!! IT was funny as hell, I had to go sort that all out for the office manager........it was a non issue.....
I have to partly disagree with you - "Anyone" can work / do maintenance on an Experimental AB Airplane.  No A&P needed or no signoff needed.  There is no requirement to enter anything in logbook except condition inspections.
FAR Part 43, except for appendix D, does not apply to Experimental Airplanes.
An ELT is not required for "local flights" (of less than 50 miles from departure place?) even in a 2 or more place plane.
My favorite IA statement is: "If it ain't logged, it didn't happen"!
 With the new OPLIMs even "Major Modifications" can be done with only a logbook entry by the owner and 5 hours back in Phase 1, with no inspection required.
Yes,  unless you have the repairman certificate, an A&P has to do the annual condition inspections, except for the first one before the airworthiness certificate is issued, and this is done by the builder and logged in logbook.   EDMO
OK I stand corrected!!!! I forgot to put my head in the file drawer and slam it a few times before I typed my message..... basically the pink certificate it tired to the operation limitions for the airplane.... EDMO is correct  anyone can work on it....... still if you are an A&P and doing the inspectiopn for someone else, be CAREFUL.... there are lots of hidden traps. As long as the owner/maintainer tells you everything he has done, you have a better chance of not falling into a trap.
We are fortunate that the FAA does not regulate experimental aircraft so much.....
Mark Smith
Rules & Regulations of Airplane Building in the USA
By Ron Alexander
We hear the word "experimental" used within the sport aviation industry on a regular basis. The most common use of experimental applies to a classification of an airworthiness certificate used for a custom built airplane. This is different from the airworthiness category assigned to an airplane that is mass produced by a manufacturer which is then sold to the general public. I will explore the exact meaning of the word experimental later in this article. Suffice to say that FAR's (Federal Aviation Regulations) pertaining to the operation of experimental airplanes can be confusing. I will attempt to clarify the confusion that exists and to simplify the regulations as they apply to building an airplane. Each phase of building and operating an amateur-built airplane will be discussed along with the applicable regulations.
In general, we are very privileged to have only a minimum number of regulations that actually pertain to building and flying our amateur-built airplane. When a manufacturer plans to mass produce an airplane, they are required by FAR's to comply with design standards that are detailed in FAR Part 23. This regulation is very restrictive as to design, weight, speed, etc.. Amateur builders are not restricted by Part 23 or any other certification regulations. Basically, our only restriction is that we must construct and assemble the majority of the airplane. (Most airplane kit manufacturers actually voluntarily comply with the guidelines of Part 23.) Part 23 is titled "Airworthiness Standards: Normal, utility, acrobatic, and commuter category airplanes." As the builder of our own airplane, which will not be mass produced, we are limited only by our imagination and ingenuity. Of course, when we build our own airplane we are going to impose strict limitations and restrictions concerning quality of construction, materials used, etc.. We certainly want a safe, reliable airplane to fly and in which to carry our passengers.
Lets define the "experimental" category and see how it applies to our amateur- built airplane. To legally fly within the United States, we must have 4 documents on board; an airworthiness certificate, a registration certificate, a copy of the operating limitations, and the weight and balance for our airplane. Airworthiness certificates are classified under 2 categories according to FAR 21.175 - standard and special. Standard airworthiness certificates are issued for most production airplanes and they are usually classed under the normal category. We are interested in special airworthiness certificates that are further broken down into several additional categories of which one is "experimental." Experimental airworthiness certificates are issued for different purposes. These purposes are: (1) research and development, (2) to conduct flight tests to show compliance with airworthiness regulations, (3) for crew training, (4) for exhibition, (5) for air racing, (6) to conduct market surveys and sales demonstrations, (7) to operate an amateur-built airplane, and (8) to operate a kit-built aircraft that was assembled by a person from a kit manufactured by the holder of a production certificate for that kit.
We will primarily concern ourselves with purpose number 7, to operate an amateur-built airplane. Fully 95% of all airplanes that we build from a set of plans or from a kit will be certificated under the amateur-built classification. Purpose number 8, the kit-built classification, only applies to kit manufacturers who have certified their airplane under a type certificate termed a "primary category" aircraft. To date, only one kitplane manufacturer falls in this category to my knowledge. All other kitplane manufacturers sell their kits to be classed under the experimental certificate for the purpose of operating an amateur-built aircraft. FAR 21.191(g) is the heart of all regulations for the builder of an airplane. This regulation states the following: "Operating amateur-built aircraft. Operating an aircraft the major portion of which has been fabricated and assembled by persons who undertook the project solely for their own education or recreation." This regulation is the essence of custom aircraft building. The intent of the classification is very clear. Notice that one or more persons may build the airplane but they must build it only for their own enjoyment or education.
Ultralight airplanes fall under a different set of rules. If your completed airplane meets the requirements of FAR 103.1, it is classed as an ultralight vehicle and as such does not require an airworthiness certificate. Briefly, these requirements are: single pilot, used for recreation only, weighing less than 254 pounds empty weight, fuel capacity not to exceed 5 U.S. gallons, not capable of more than 55 knots in level flight, and a power-off stall speed not exceeding 24 knots. As you can readily observe, the majority of custom built airplanes exceed one or more of these criteria. Often, the owner of an ultralight airplane will choose to certificate their aircraft under the experimental category. This is usually done to comply with the regulations regarding weight, passengers, etc.. Note that the operator of an ultralight does not have to be a certificated pilot contrasted to the operator of an amateur-built airplane who, of course, must be a licensed pilot and the holder of a current medical certificate.
To continue our discussion of FAR 21.191(g), it is clear that to certificate an airplane under the experimental category for amateur-built operation, we must assemble and construct at least 51% of the airplane. The FAA emphasizes this restriction in at least two publications. The first is FAA Order 8130.2C, which is the airworthiness certification manual used by FAA Inspectors as a guide to inspect an airplane and to issue an airworthiness certificate. On page 116 of that guide, the following guidelines appear under the eligibility section. (1) "Amateur-built aircraft may be eligible for an experimental airworthiness certificate when the applicant presents satisfactory evidence that the aircraft was fabricated and assembled by an individual or group of individuals." This section goes on to state that the project must be undertaken for educational or recreational purposes and the FAA must find that the airplane complies with acceptable standards. Aircraft that are manufactured and assembled as a business for sale are not considered to be amateur-built. This statement appears within the Order: "NOTE: Amateur-built kit owner(s) will jeopardize eligibility for certification under FAR 21.191(g) if someone else builds the airplane." The applicant for amateur-built certification must sign a notarised form (FAA Form 8130-12), certifying the major portion was fabricated and assembled for educational or recreational purposes, and that evidence is available to support the statement. The second place the 51% rule is emphasized is in Advisory Circular 20-27D on page 5 under 7(b). This section simply emphasizes the major portion rule.
When you purchase an airplane kit from a manufacturer, the kit should be listed on the FAA listing of kits that have been evaluated to ensure that 51% of the building will be completed by the purchaser (this is commonly known as the "major portion" rule). I want to emphasize that the FAA in no way endorses any of these kits nor do they approve kit manufacturers. They simply evaluate the kits solely for the purpose of determining if an aircraft built from the kit will meet the major portion criteria. A listing of these kits is available from your local FAA office. I do not recommend purchasing a kit that is not on this listing unless you are prepared to prove to the FAA Inspector that the kit meets the proper criteria.
The FAA does not expect the builder to personally fabricate every part of the airplane. A number of items can be purchased and several tasks can be contracted commercially. FAA Advisory Circular 20-139 titled "Commercial Assistance During Construction of Amateur-Built Aircraft", provides a very detailed guide concerning what can be purchased complete and what can be contracted commercially. Engines, propellers, wheel and brake assemblies, and standard aircraft hardware are examples of items that may be purchased. Installation of avionics, painting an airplane, and upholstery items are examples of tasks that may be contracted. The bottom line of the entire discussion is that you must prove to the FAA Inspector who issues your airworthiness certificate that you have complied with FAR 21.191(g). Next month we will discuss the necessary documentation to present to the inspector to assure your compliance.
If you decide to allow someone else to build your airplane to be certificated as amateur-built, you will be required to license it under the experimental category for the purpose of exhibition. This category is much more restrictive than amateur-built. The purpose of this category is to allow the holder to exhibit their airplane at air shows, motion pictures, television filming, etc., and of course to fly to and from these productions. I will not spend time discussing this category since it is rarely used.
Now that I have discussed the general regulations concerning building your airplane, I will detail specific regulations as they apply to each phase of building, flying, and maintaining an amateur-built airplane. I would recommend that you obtain a copy of the regulations for your own reference. Several books are available that contain the FAR's along with computer discs containing all of the FAA regulations. The FAA also maintains a web site with all regulations. This site can be found at www.faa.gov.
(Visit "Helpful Links" on this web site for many links to the FAA)
Initial Building Phase
The first phase of construction is, of course, the building phase. I would highly recommend that before you begin your project you ask your local FAA office for their information packet that is available relating to amateur-built airplanes. Part of this packet is Advisory Circular 20-27D, that you will refer to regularly. Regarding regulations governing the first phase, we have discussed in detail FAR21.191(g). Another regulation, FAR 21.173, presents the eligibility for an airworthiness certificate. FAR 21.191 defines all purposes that are allowed for licensing under the experimental category including, of course, amateur-built. FAR 21.175 defines the classifications of airworthiness certificates. FAR 21.193 contains the information that must be submitted for an experimental certificate. Advisory Circular 20-27D presents this information much more completely. FAA Part 45 details the markings that are necessary for your aircraft with respect to what is required, size, location, etc.. FAR 45.23 is where we are told that we will display the word "experimental" in letters not less than 2 inches high nor more than 6 inches high near the entrance to the cabin or cockpit. FAR 45.29 provides us with the size of registration marks and specifically allows us, as owners of experimental aircraft, to use 3 inch high numbers and letters providing our maximum cruising speed is less than 180 knots. If our cruising speed is higher than 180 knots, then we are required to use 12 inch letters and numbers. An additional regulation applies if our airplane had an experimental certificate issued more than 30 years ago. This regulation allows us to use numbers and letters only 2 inches high. FAR45.22 specifies the rules as they apply to the older airplanes. Details of spacing, width, and other factors are discussed in this section.
Continuing the building stage, FAR 47.15 informs us about registration numbers. You may select an "N" number of your choice providing the number is currently not in use on another airplane. FAR 47.33 lists the information that must be submitted with your application for the "N" number. If you intend to fly your airplane at night or under Instrument Flight Rules, you are required to have specific equipment. The necessary equipment, including instruments, radios, etc., is outlined in FAR 91.205. This regulation also tells you what is needed for VFR flight during the day. FAR 91.207 outlines the requirements for emergency locator transmitters (ELT). The requirements for an ELT are basically the same for all airplanes, including amateur-built. It should be noted that if you remain within 50 nautical miles of your home airport and you are engaged in flight training, you are not required to have an ELT. Also, if you have a single place airplane you are not required to install an ELT.
Obviously, there are a number of other issues involved in the building phase.
Flight Testing
FAR 91.305 defines a flight test area. Basically, it states that you must conduct your flight testing over sparsely populated areas having light air traffic. FAR 91.319 provides a listing of operating limitations. As I mentioned, when your aircraft is inspected you will be given a copy of operating limitations. Usually, the inspector will issue Phase 1 and Phase 2 at the time of inspection providing you with 2 sets of operating limitations; flight testing and subsequent operation. The flight test area is defined within the Phase 1 limitations along with the required number of hours you must fly the aircraft. The primary restrictions regarding flight testing are: (1) no passengers, (2) day, VFR only, (3) no operation over congested areas, (4) you must advise ATC that you are experimental, and (5) the pilot must have the appropriate ratings. Of course, the general operating rules under FAR Part 91 are applicable. Phase 1 operating limitations have an expiration time of 12 months from date of issue. All flight testing must be completed within that time period or the aircraft must be reinspected. One of the restrictions, in FAR 91.319, that is interesting is that in order to have the Phase 1 restrictions lifted you must prove that the aircraft has no hazardous operating characteristics and that it is controllable throughout its normal range of speeds and maneuvers. The FAA has an Advisory Circular that is very helpful in providing guidelines for flight testing. This circular, Advisory Circular 90-89, is necessary to read prior to your first flight. Also, the EAA Flight Advisor program is highly recommended. The flight testing phase should be an enjoyable conclusion to your building experience and it will be if planned and executed properly.
Normal Operation of Your Amateur-Built
Once again, all of the general operating rules under FAR Part 91 apply to daily operations of your aircraft. In addition, the operating limitations presented under FAR 91.319 and as issued by the FAA Inspector at the time of inspection govern. After completion of Phase 1, you are then allowed to carry passengers and fly at night or IFR if so equipped. Phase 2 limitations do add some restrictions that merit discussion. First of all, you may not carry passengers or property for hire. Secondly, any major changes that are made to the airplane as defined by FAR 21.93 require inspection by the FAA prior to further flight. A minor change is defined as one that has no appreciable effect on the weight, balance, structure, or anything affecting the airworthiness. Examples of a major change would be a different horsepower engine, a different pitch propeller, a change in basic design, etc.. If a major change is made notify the FAA in writing providing the details of the change to ascertain whether or not an inspection will be required. Thirdly, you may not operate your airplane unless it has received a condition inspection (annual inspection). This will be discussed in the next section.
Maintaining Your Airplane
As I mentioned in the previous section, a condition inspection is required every 12 calendar months on amateur-built aircraft. This check is similar to an annual inspection required by FAR Part 43 on production airplanes. The Phase 2 Operating Limitations specifically refer to FAR Part 43, Appendix D, as the guide to performing this inspection. The inspection can be performed by any licensed A & P mechanic, an FAA Approved Repair Station, or by the builder of the airplane provided the builder obtains a "Repairman’s Certificate" from the FAA. FAA Advisory Circular 65-23A is available for information concerning application and privileges of this certificate. In short, the primary builder of the airplane is eligible to apply for this certificate which then permits inspection of the airplane and a logbook endorsement of the condition check. It is noteworthy that the primary builder must be one person. If a group of people builds an airplane, only one can be designated as the primary builder. In addition, the issuance of the repairman’s certificate only applies to the one airplane that has been built by the primary builder and no other airplane regardless of same type, etc..
Normal maintenance on an experimental airplane can be performed virtually by anyone regardless of credentials. Once again, this does not apply to the condition check previously discussed. You can perform maintenance items on the engine whether or not it is "certified". Once a certified engine is placed on an amateur-built aircraft and is operated, it no longer conforms to its type design. This means that the engine can no longer be placed on any aircraft other than an amateur-built until it has been inspected and found to meet its type design. It also must be found to be in a condition for safe operation "airworthy". Once again, common sense should rule. We do not want to overhaul an engine on our airplane unless we are equipped to do so with tools and proper knowledge.
I will point out that FAR Part 43 specifically states that the rules of that part do not apply to amateur-built airplanes. With that in mind, anyone can maintain the airplane. However, remember in our earlier discussion that Part 43, Appendix D was referenced in Phase 2 operating limitations presented to the builder at the time of inspection. It is referenced as a guide to be used in conducting condition inspections. That means Part 43, Appendix D does apply to the condition inspection because of this reference. The FAA has further clarified AD (Airworthiness Directives) as they apply to amateur-built airplanes. Airworthiness Directives cannot apply to any part on an amateur-built airplane unless that specific airplane is cited along with who should do the work and to what standards. The reason for this is because once an approved part is placed on an experimental airplane it is no longer considered an approved part. Again, let me emphasis that just because a regulation does not require an action it still may be prudent and within our best interest to conform to an AD note. We are striving to improve the safety record of this industry and in all cases we must act on the side of common sense and good practice.
Regulations Involving The Sale of Your Amateur-Built
There are few regulations governing a sale of your airplane. The airworthiness certificate is transferable with the airplane even though it is experimental. (FAR 21.179) The proper bill of sale and registration documents must be completed when you sell the airplane. Of particular interest is the fact that the new owner may maintain the newly purchased airplane, but may not perform the condition check. The repairman’s certificate is not transferred with the airplane. It remains with the original primary builder. That person legally may still perform the condition check if you can persuade them to do so. If you are purchasing a partially completed kit you need to obtain the proper documentation to ensure you will meet the major portion rule. FAA Advisory Circular 20-27D has the following warning: "CAUTION: Purchasers of partially completed kits should obtain all fabrication and assembly records from the previous owner(s). This may enable the builder who completes the aircraft to be eligible for amateur-built certification." Once again, a call to your FAA Inspector will prevent future problems. The time spent by the original builder is usually applied toward the total time required to build the airplane. Documentation is necessary.
Summary
The following table will provide a concise summary of Federal Aviation Regulations as they apply to amateur-built airplanes. Next month I will detail forms, documentation, etc., necessary to certificate your amateur-built aircraft along with an easy to use checklist.
PHASE OF CONSTRUCTIONFARDESCRIPTION
INITIAL BUILDING21.191Basic definition of amateur-built.
 21.175Classification of airworthiness
 21.193Needed information for experimental licensing.
 45.22"N" number rules
 45.23Experimental display
 45.25Location of "N" number
 45.29Size of "N" number
 47.15General information - "N" number
 47.33General information - "N" number
 91.205Instrument & equipment requirements
 Advisory Circular
20-27D
Certification & Operation of Amateur-Built Aircraft
 Advisory Circular
20-139
FLIGHT TESTING91.305Flight testing area
 91.319Operating limitations
 Advisory Circular
90-89
Amateur-Built Aircraft Flight Testing Handbook
NORMAL OPERATION21.181Duration of airworthiness
 91.25Accident Reporting
 91.207ELT requirements
MAINTENANCE21.93Major & minor alterations
 PART 43,
Appendix D
Condition check
 Advisory Circular
65-23A
SALE21.179Transfer of airworthiness
YOu can go to FAA.gov and look up 8900.10 which is the handbook guidance for FAA inspectors.. it is a difficult to read sometimes but it tells the inspector how to do a ramp check.....among other things....
Now, I need to go find that file drawer!!!!or have a shot of vodka.... I am so glad to be out of the Fu&&in FAA rat race ... the managers tell you what to do,
whether or not you like it and a lot of times they are wrong...
I had a new inspector do a ramp check on a PA-18 I was working on outside... He started to write up things he didnt like....then he asked me if this was a Citabria.!!!
I said no , its a PA-18 super cub... I said hey do you have a business card? He proudly handed me one.. I said it is apparent to me that you do not know what you are doing so I am asking you to leave my premises and I will be in touch with your supervisor. He left..... I called his boss and said DO not send that idiot back out here. He is a danger to the GA  pilots and planes in the area. He obviously needs more training. I told them if they persisted in sending him back to my airport, I would file a congressional complaint... He never came back.  They are like rats and have little boxes to check off in thier "wolrk program".
Granted there are a few good ones and eventually you will learn who they are.....but by no means should you be afraid of them. IF you feel threatend, document everything, take photos of them and if you have to file a congressional complaaint... THe congressman will make them answer for what they did....maybe even put them on an ODP (opportunity to demonstrate preformance) in order to keep their job......
I think Some of them are responsible, aircraft-minded, honest workers just doing their job.   Some of them are Gov-ment Employees just drawing a paycheck while doing little of nothing.  And, Some of them are idiots who never should be allowed on an airport!   Just the normal bunch of characters we have on earth.  ;<)  EDMO
I have to say that the ones I have dealt with have been decent people.  I did try to treat them with respect as well, and that helps I think.  One of them had been working up in Alaska before he moved back to Mn, and he told me how he was restoring his Champ. The one that he almost lost in a river up there when he turned around on a sandbar and the tail dropped into the river.  He was a real nice guy who obviously loved airplanes.   JImChuk
"OK I stand corrected!!!! I forgot to put my head in the file drawer and slam it a few times before I typed my message..... basically the pink certificate it tired to the operation limitions for the airplane.... EDMO is correct  anyone can work on it....... still if you are an A&P and doing the inspectiopn for someone else, be CAREFUL.... there are lots of hidden traps. As long as the owner/maintainer tells you everything he has done, you have a better chance of not falling into a trap.
Mark Smith"
Mark,  You are totally correct on this - "A&P Beware!"  Most of you are not A&P certificated, but if you are, then you are completely responsible when you sign the condition inspection - There is a huge liability there!   I have a plane that crashed on the way home after an A&P CD was done because the oil tank was empty.   One guy with an Experimental plane that I was not familiar with asked me to do the CD on his plane so he could sell it after I had heard some bad rumors about it - I asked $1000 for that, so he found someone else.  I would have had to have all current FAA books and maybe buy the plans for it and get all ADs and Service bulletins and letters for a start, in addition to traveling 200 miles roundtrip, and I probably would have failed it anyway for something he didn't fix, or maybe missed something on it.   There was too much liability there for me.    EDMO
