Rotax oil pump
5 posts in this topic
Hi guys I was hoping that someone could help me determine what the top hose bib goes to. I'm new to Rotax and have read everything I can get my hands on and can't seem to find an answer. Thanks
The oil supply line hooks on there. JImChuk
Thanks Jim, but what is the source? My 2 stroke oil tank is hooked up to the engine supply and return on the case as per the Rotax manual. Thanks
Are you talking about the RV oil bottle that is hooked to the case?  That is strictly an oil bath for the rotary valve shaft.  You will need a larger external oil tank for the injection oil.  It is shown pretty clearly in the Rotax installation manual.  If you don't have a copy of it one is posted on this site in the files and forms section.
Thanks guys, It was a Duh??? on my part. I now understand the difference. I'm good to go.
