Lexan vs Acrylic - help!
3 posts in this topic
Hi All,
Getting ready to replace the windshield and doors - and trying to decide between Lexan vs Acrylic/Plexiglass.
I've been reading through the archives here and at TeamKit - and there are good arguments for both.
Seems like most posts have been on use of Lexan, but a few mention Lexan's sensitivity to gas, UV, and crazing around bends and so strongly recommend acrylic.
The price here is almost the same 4'x8'x1/16th" sheet of Lexan ~$62 and $75 for Plexi - so pretty much a wash there.
Downsides on acrylic I've read are propensity to crack when drilled or bent, easier to scratch but much easier to buff.
The plane sits outside with a cover.
So any suggestions?    Which way should I go?   Do I heat at the forward spar bend?
Cheers,
Owen
I wouldn't consider plexiglass at all.  I don't believe you could ever bend it around for the windshield without it breaking.  Unless it's melted in a mold to the right shape.  Then the windshields are 1/8" thick.  Had one for a Kitfox.  Went to install it, lifted one corner up about an inch, and heard a plink sound.  Crack just like that.  That was about $500 went right out the window there.  It came with a partly finished kit I bought, sure am glad I didn't buy it myself, I would have..... I don't know..... not been happy. Others have had similar experiences.  JImChuk
I did the molded windshield and skylight with out incident.   Bubble doors too.
I would do them again in a minute.
