Building question- Mark IV
5 posts in this topic
Does anyone have some photos and suggestions on how to install the lower aluminum sheeting (under side) behind the firewall going aft. I have a frame with the nose wheel weldment and would like to see how others have installed these pieces. ( 2 halves)
Thanks for any help you can provide.
here's a couple pics. just make a template from cardboard and cut a notch that will fit under the rear brace tube. I have about a 1/2" overlap in the center and there attached with some 1/4 long sheet metal screws into the tubes
birddog,
Are those red fuel lines on the belly?
Nope, not fuel. Those are oil lines that run between the engine and oil tank that's fitted under the baggage area.
Thank you.  Helps give me an idea of how to install them. Much appreciated!!!!
