The unquenchable EGT
29 posts in this topic
Since day one of my little planes new life I have been unable to get my cruise EGT temps to acceptable levels.
Here is the things I have done or tried:
1. Checked probe location and found that someone had placed the probes holes 3.5 inches out on the Exhaust Manifold. Welded up the holes and re-drilled them 38MM (1.49 inches) out from the face of the port. Installed new probes.
2. Rebuilt cards with new jetting and leaned the Idler circuit
3. Needle clip to the richest setting. Anything leaner that the richest position made the EGT temp rise over 1200 in cruise.
4. Added pitch to the prop. This was the only thing that seemed to help but it took so much pitch that the performance was not acceptable for normal operation.
5. Purchased a longer propeller to load the engine. Again high pitch setting was the only noticeable difference.
6. Purchased and installed one size bigger Jet needle. Didn't see much of a change to the mid range as reported by others. In fact I seen a slight raise in the temps.
7. Read every article I could find. CPS, Ultralight news, several independent articles, this form, Kitfox form, and the Rotax form. Most articles I copied and saved in my builders reference manual.
8. Monitored Plug color per Jimchuk. The plugs said I was OK so I continued to keep searching.
I was talking to a friend the other day and was explaining to him what I'd been dealing with. He asked if I had tried a larger main jet. I told him that my temps were good at WOT and I didn't believe this was the problem. He suggested I install the next larger main jet, run it at the current needle setting, lean the needle if needed and see if that had any effect on the my mid-range problem. At this point I was willing to try anything. I threw in the next bigger set of main jets and took it for a flight around the pattern. What did I see......hotter EGT temps than before. You have to be kidding me I thought!!! I thought adding fuel cools the circuit?? Why was it that every time I added more fuel with a jet temps showed hotter???
I went home, got my articles out and started reading through them again. I found the answer and it had to do with the installation of the EGT probes. If you use the 1" EGT probe (which I did)you have to shim the probe out with 7 AN-3 washers (which I didnt) so the tip of the probe is placed inside the manifold no deeper than half the diameter of the pipe. If you insert the tip of the probe all the way to the other side you are outside the cone of the flame. The cone of the flame (cooler part of the flame) is where the temperature is supposed to be taken. Anything outside of that area will produce hotter readings. As the article explained.... you will know this by raising EGT temperatures if you enrichen the circuit. When you add more fuel to the system the excess fuel gets pushed out of the cylinder and is burned inside the manifold. The more flame the hotter temp
Now you can purchase probes with 1/2 inch long sensors right from Westach. The bayonet probes can be adjusted. Unfortunately I cut the excess clamp off which made one of them to short to add the washer between the probe and the pipe. I was able to install washers under one of my probes. So far it looks like this was the problem all the time.
A lot of the headaches I've ran into with buying someone else's project was because things were installed incorrectly some of which I took apart and reinstalled back the same way. If you buy someone else's project it never hurts to double check the installation instructions on everything.
I hope this will help someone who may have the same issue or as Joey called it is" Chasing a Mermaid".
Edited by NorthIdahoAvidflyer
addition to text
I thought the EGT probes were supposed to be 10cm out from the flange!
I was in the same boat when I got my plane. I got it in a April and didn't fly until October because of the mess the previous owners made. It definitely sucks but you'll get a better understanding of your plane if you rip into everything and inspect it yourself.
Not sure where you got those numbers. 38mm or 1.49 inches from the flange face.
I was mistaken.  the 1990 version of the 582 manual states, on page 15: "Cylinder head temperatures are measured at the spark plug seat.  Exhaust gas temperatures are measured at 100 mm (3.94 in.) from the cylinder sleeve."   It would seem logical to use the flange as the reference for these probes, but no!  I had now better check the locations of my EGT probes. Thanks for the correction.
Just to muddy the waters even more, the 1990 build manual says to drill the holes for the EGT probes 4" away from the lower edge of each flange, measured along the bottom centerline of each branch of the "Y" (this is indicated in a sketch).  It also says, in a footnote: "Absolutely precise location of EGT probes is not critical.  The attaching bands will 'effect' {affect} exact location.".  Oh Boy!  It appears likely that new things have been learned since 1990!   My probes are certainly not 38mm out from the flange center, more like 50mm.  So Vance, where did that drawing come from?  Does anybody else want to chime in here?  I've been believing that my EGTs were significant.  I was even contemplating a T-compensated digital gauge to replace my analog ones.  If location of those probes is more critical than it says in my 1990 build manual, I at very least will be more careful about keeping my EGTs away from the 1200F limit.   My probes are about 3-1/8" out from flange bottom, measured along the bottom of the Y branches on centerline.  Any further out, and the bands wouldn't fit.  .
Edited by Turbo
Find a newer engine to look at. The newer engines have prewelded bosses on the manifold in the correct location.
Wow! Another clear-as-mud discourse on where to drill the damn hole!  It'd be tempting to just get a new Y-manifold with the holes pre-drilled, but for the doubtless exhorbitant price!  Isn't EGT really only about keeping the plugs clean without melting a piston?  If mine read high due to the probes being too far downstream, i reckon it's conservatve if the probe tips are centered in the ducts.  I think I'll validate the latter, then call it good enough!   Thanks for digging into this, Vance!
Edited by Turbo
I found two other places where it said to place the probe out 100 mm from the piston skirt on a 582.  I believe you are right that the probes could be close to the specified location and you may not see a lot of temperature difference. When my probes were out at 3.5 inches the EGT's showed over 1300 every time I ran it. Mind you the tips of my probes were still stuck all the way through to the outer edge of the pipe so I could not really tell you what actual placement difference makes. It makes sense to me that if you put the probe in the hotter part of the flame that you will get a higher reading. From gas welding you will learn that the tip of the cone is the hottest part of the flame and the inner cone is the cooler part of the flame. It makes sense that the probe should be placed inside the center of the cone. The goal is to monitor the relationship between the mixture and the heat being exerted on the piston. I will be able to tell you more once I install the new probes how much of a difference tip placement really makes.
THe main problem is that we all post what we believe, or what we were told, or what we remember, so it becomes clear as mud. Then we say stuff like "wow it's confusing." No it is not confusing, it is as clear as can be, if we bother to just read what the manufacturer said to do. This is from the installation manual, written 19 years ago:
Thanks, Nick.  That's nice and clear, unlike some other sources.
I received and installed the new probes yesterday afternoon. I took it around the pattern a couple times and it appears the new probes have decreased my EGT's by 100 degrees. This puts me in the 1100 range instead of the 1200 range. If anything else it makes it nicer to look at.
Nick, Thank you for posting the picture. 100 MM from the piston skirt is what all the articles I read say. Not sure why the Avid Construction manual said to put the holes out so much further. I have two Rotax 582 manuals downloaded on my phone and either of them mention EGT probe placement. They are newer manuals. It does talk about EGT limits. They must be service manuals and installation manuals. I will find the specific installation instructions and download them also.
pretty sure the install and service manuals are on this site :)
nice link!  Look under historical documents for the repair manual.
Update: I flew several hours this last weekend and I could not be happier with the EGT temps. I'm running a steady 1125/1125. Changing the probes to the right location made all the difference. I actually found myself watching the EGT's less and less over the weekend.
After several months its so nice to find and fix the problem. Of all the things I read there was little mention of probe placement. The Devils in the Details.
Thank you for all the advice.
spelling
Vance is absolutely right on this egt probe placement.. I went thru the exact same problem.. mine were too far out and the holes drilled from the side.....once I got it set up properly, everything fell in place and the egts read normal now.....mine run about 1050-1100 depending on where the prop pitch is set.... the prop pitch will affect egts but yo9u need to know you acan trust the egts readings before making other changes.....
Looking into this same issue, and not because my EGTs looked particularly weird, I found the exact same situation Vance did.  It's just that I would like to trust my EGT readings vis-a-vis the database for what keeps these engines alive.  It seems the manufacturers of these probes thought they ought to be 1"long, which sho-nuff puts the probe tip over by the opposite wall of the Y-pipe.  It's like they just decided to market the same probe for the 582 that was being used for some other engine with a 2"diameter round exhaust pipe.  (O.K., Turbo, enough whinging!)  I'm still not sure how to proceed: Buy a new pre-drilled Y-pipe and threaded probes, or try to drill new holes in the proper location, and re-use the old ones.  With the latter approach, I need about 1/2" worth of spacers, putting much of the probe's length outside the Y-pipe in a much cooler environment.  Will this give artificially low readings due to heat conduction along the probe?  If only the necked-down probe tip is where the thermocouple is, with the relatively low thermal conductivity of steel, I am thinking not.  On the other hand, I am not too keen on my current EGT gauge setup.  Still pondering this one.
Here are some thoughts and ideas. If you look around (believe it was the Avid building manual) there are directions on installing the longer probes. They call for 7 AN3 washers to be placed on the probe to shim it out. I would not worry about the probe cooling because  the washers are in direct contact with the pipe and should insulate the exposed portion of the probe.
I was going to shim mine out but I had cut the excess tail off of the clamp when I first installed them (big weight savings) . Once the washers were installed the clamp was to short. I got on the Westach web site and found that they make the same series of probe with a half inch long probe. I ordered new probes and they work perfect.
If I had to do this all again I would replace the Westach with a Micro 1000 from Aircraft Spruce. I have ran them before on other planes. They work great and self adjust for ambient temperature so the probes read correctly all the time. I was on a budget at the time and figured new probes for the Westach were cheaper than a whole new gauge. After it was all said and done I ended up spending money for two sets of probes and didn’t save much money over a new gauge.
 :lmao:
I think most people running Rotax 2 strokes use the longer EGT probes.  The 1/2" ones are usually used on the 912 or Jabiru as both have smaller diameter exhaust pipes.  Here is a link to Westach's EGT probe page.  JImChuk
westach.com/products/ACCESSORIES/EGT%20THERMOCOUPLES/CLAMP%20ON%20TYPE%20THERMOCOUPLES/index.php
I’m sure plenty people use longer probes but there is instructions on how to shim them out so the probe tip stays in the center of the pipe and plenty of articles related to proper probe placement in the cone of the flame. When I went to the leading aviation supply store to order probes they did not offer suggested lengths for specific applications. It took reading the Rotax install manual along with Rotax tuning articles from various sources to make the simple conclusion that it comes down to probe type, where it needs to be in the system and how far it needs to be from the skirt of the piston. I always buy direct if it saves me a few dollars and when I went to the Westach site it offered shorter (1/2 inch) probes that the other distributors didn’t. An email to them confirmed this probe would have the proper needed reading for my gauge and application. Plugs still reading good color as before and the gauge now shows a reading that matches what the plugs say.  I’m happy with my outcome. To each their own.
Measured off the 38mm and yowtza!  That's a big difference!  Does this look right to y'all?  The pencil marks are where the new holes will go.
Edited by Turbo
Those old jholes are not right. Mine was the same. You will notice they are both out near the Y of the pipe. That will produce higher EGT readings.  You are on the right track.
I reckon i'll go visit the local welding wizard tomorrow to get the old holes closed up.  The probes are very close to a numbered drill size, so I can drill the new holes for minimal clearance & leakage.  I have drilled out a few #10 nuts to use as spacers, along with a few ss washers.  Thanks, Vance,, for digging into this issue to such depth.
