How to remove stiffeners
4 posts in this topic
Fellows, I am trying to get the spar stiffeners out of the wings and I can't find anything that will loosen the glue.  What is the trick to this?  Also, the one stiffener I can see looks like regular plywood.  It looks to be a 3 ply.  Also, they didn't center the stiffeners on the strut fitting.  Should it be?  Thanks for the help.
Jim
a heat gun will soften the glue and you should be able to knock it out.
Thank AK I'll try that tomorrow.
Thanks again AK.  Heated the tubing up pretty good and started working it with a piece of wood.  It took a couple of tries and it finally broke loose.  Had to clean the tube good afterwards, but it worked.  Thanks again.
Now I am getting ready to extend the wing and make a long wing aerobat wing.  I am only extending it 3'.  Will I have problems with that or is that the correct length?
