can someone confirm datum line
8 posts in this topic
i'm doing some calcs, and can't remember if the tail dragger avid c main axles are 1.5" -ish aft the 0 datum, or forward.
Edited by Matthewtanner
Definatly forward on the ones I've measured.  I seem to remember 3/4" forward.  JImChuk
My records show for original Avid tail dragger gear,  -1.6" for main axles, which is forward of the wing leading edge (the datum).
yikes, i've been flying with it forward of cg...for some reason i seemed to remember when i leveled out the aircraft, the axle was behind 1.5"....at least i know it flies ok forward of cg.
move your CG back to 16" or 18" and you will be shocked how much better it flys...
yea, now i'm gonna try to find where i can source lead shot locally to make a weight bag. i was flying around at 11.2 cg because i didn't minus the moments of the front wheel weight, i added them.
not that it's gospel...but on the manual page 1-9 the example for the nose gear is "-" but the tail dragger the mains are "+". I could travel back out to the hangar and just level out the aircraft and drop a plumb line, but the manual plus i just for some reason remember the axles being behind....but really it doesn't make sense that they would be.
I couldn’t take it boys....had to go do just that. My axle behind leading edge, which means my cg a-ok
