Fuel Pressure Regulator
2 posts in this topic
Im putting a 582 gray head motor in my Skyraider that Im building.I was wondering if you guys run fuel pressure regulators.I have the stock dual pump plus I have a backup electric pump just for priming or emergency purposes.It is supposed to put out 2 to 4 PSI.I have it plumbed through a shut off valve and it goes around the diaphram pump and not through it.Thanks Randy
I dont think that many are running a regulator. I too have an electric back up pump and use it just to prime and also to boost in instances where my fuel filter was plugging up. I dont see a need for a regulator unless you are running fuel injection.
